2004 wrx ej205 to ej207
Results 1 to 14 of 14
This is a discussion on 2004 wrx ej205 to ej207 within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi all, im new and just wanted some opinions/ideas for my new engine. My 04 wrx engine just died (combo ...
    Jan 2009
    My 04 wrx engine just died (combo of negative temp days, wrong oil maybe, improper upgrading by previous owner..) anyway, that shenanigans aside- i decided to go the ej207 route instead of finding another ej205 oem.
    The day the engine arrived, the shop informed me that this engine came with a twin scroll turbo. They asked if i want to go ahead with the instal and recommended a tomioka TS usdm fit downpipe and a catless bell mouth downpipe. They also want to do an open source dyno tune instead of the Cobb accessport route.
    Also a 76mm invidia q300 catback system
    -- aem cold air intake
    -- gates timing belt
    -- they said a new uppipe is not needed
    Any thoughts here, are these suggestions inline with what you guys have done?
    Thanks in advance!
    Im in Pa, usa by the way
    Moderator Donkey's Avatar
    Da boonies,Va
    Pretty basic mods. As long as it's getting tuned it should be fine.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2012
    Rocky Top
    I'm assuming since it came with the turbo it also came with the twin scroll headers and up-pipe? Sounds like a pretty cool swap Gonna keep us updated?
    MTM
    MTM is offline
    Registered User MTM's Avatar
    Feb 2014
    NorCal
    he didnt.... booo
    Im thinking about doing this.. strongly.
    Jan 2009
    If you guys are interested i can post the details on the swP
    MTM
    MTM is offline
    Feb 2014
    NorCal
    Do it. It would only help. Im sure there are others, but Id like to see. I have my motor out right now and am probably going to put the 207 in my car
    Jan 2009
    What tranny are you running now? 4eat? 6speed? What v ej207 are you looking at?
    Oct 2013
    Could of went with a ej255 or 257
    Sent from my GT-P3110 using Tapatalk
    Jan 2009
    Dont underestimate the ej207- im dyno'd @ 285 whp 6200 rpm
    Jan 2009
    Had the 4eat rebuilt and upgraded the clutch holding capacity. Also put in a shift timing kit to make it shift nice and firm. Loaded the AT roms from a jdm non sTi WRx. They didnt work correctly. Went back in and repinned the ecu/tcm to run the at load off the maf signal. Also repinned some wires to get the correct torque signals.
    Car runs great now- very quick.
    Recap:::
    Ej207 swap into 4eat 2004 WRX
    Downpipe
    Twin Scroll
    Cat back
    Air Intake
    Dyno tuned
    285/285 whp/wtq
    MTM
    MTM is offline
    Feb 2014
    NorCal
    Are you running USDM ECU then?
    Jan 2009
    Running the ej207 jdm 16bit ecu. It took alot of work to figure out... Usdm ecu would not control avcs so the extra work is well worth it
    MTM
    MTM is offline
    Feb 2014
    NorCal
    Im not sure the difference between the different transmissions, but there are extensive wiring tutorials on Nasioc? did you use those?
    Jan 2013
    I have a 04 wrx and my motor went on me in January. I purchased a jdm Sti ver9 twin scroll motor and a ver8 jdm ecu to run the motor.
    Came with stock downpipe which is bellmouthed. I gutted the cats and the downpipe is good to go until I can afford an aftermarket because of the twinscroll flange it so expensive.
    The motor swap was done by me and a couple buddies in a garage in a weekend. Drive the car home Sunday morning.
    The swap was completely direct bolt in!
    I'm currently running the jdm ecu with the motor with no problems at all.
    I will get it all tuned on that ecu and then get the usdm ecu tuned to force ready codes and save that for the emission testing.
    The twinscroll is amazing! Love the torque low and high end!
