Considering Forged Internals?????????
Results 1 to 9 of 9
This is a discussion on Considering Forged Internals????????? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I picked up a clean as heck 2002 WRX about a week ago. It was tuned a few months ago. ...
    Jan 2014
    Minnesota
    Question Considering Forged Internals?????????
    I picked up a clean as heck 2002 WRX about a week ago. It was tuned a few months ago. Not stock, has intake, exhaust, 3in intercooler piping, ball bearing turbo thats ported, Clutch, and a few others. stock trans. 5 speed. I can hear a knocking/tapping sound very slightly when holding the throttle completly still from about 2600rpm to 3400rpm. unlucky me i am guessing its rod bearing. i was thinking if it will make it till March i could daily my 240sx and tear down the subie. i was thinking while its apart to do some forged internals for extra saftey. I could dump maybe $2000 into parts and do all the labor. Cars at 320hp and i am fine where its at. it is my Daily driver and i want it to be my daily for another 100k miles. what do you guys suggest?
    Thanks!!!!!!!!
    Moderator Donkey's Avatar
    Da boonies,Va
    3" inter cooler piping?
    2002 FORESTER S
    1998 FORESTER S
    Jan 2014
    Minnesota
    Yes, it has a front mount intercooler and all the piping is 3".
    Jan 2014
    Minnesota
    It's making a short grrr noise right when you let off at 5,000rpm now.
    Da boonies,Va
    Without hearing the noise it could be several things. No way to correctly diagnose without audio
    2002 FORESTER S
    1998 FORESTER S
    Palmyra, NJ
    So what exactly are the mods? There are 9 million different ball bearing turbos out there...tons of different FMICs with 3" piping...millions of intakes...
    Sounds like you need to figure out what exactly you have before you figure out what you should do. You have a dyno sheet saying 320hp or is that what someone told you?
    You won't make it another 100k as a daily driver.
    Jan 2014
    Minnesota
    IHI VF22 Ball Bearing Turbo (Modified with Port Work)
    Front mount Intercooler Kit 3" piping (Austrailan Made) Bar and Plate with Polished End Tanks
    HKS SSQV Blow off valve
    AEM Air Intake (modified for short Ram) with K&N filter
    Aluminum Crank Pulley
    3" Full Stainless Steel Exhuast (Invidia Style) Polished
    3" Electronic Cut out from QTP controlled from the dash via switch
    STI 565 Injectors from Japan
    255 lph Walbro Intank Pump
    Cel Kit
    Greddy Style oil catch can
    T304 Stainless steel UP pipe w/ flex section and 3" DownPipe
    Iridium Spark plugs 1 heat range cooler
    Mark Halman Boost Controller, Rock Solid
    DXD Clutch Kit DXD-F (Feramic, graphite and cindered iron) 'Will hold all the power with stock feel'
    Earth R1 ground wires
    Car is at 319hp, I have the dyno sheets.
    Jan 2014
    Minnesota
    For the guys at ClubWRX. - YouTube
    Should be the link to a video. Knocking starts a few second in. Also listen to the blow off. Had one tech tell me it's completely fine. But I've heard that flutter noise is bad. Please elaborate for me. Thanks for the responses guys!
    Jan 2014
    Minnesota
    10 seconds in the noise starts...
