2013 Wrx Engine Problem
Results 1 to 15 of 19
This is a discussion on 2013 Wrx Engine Problem within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Having a huge problem with my bolt on 2013 Wrx. Mods are stage 2 plus EWG and FMIC. Protuned and ...
    Registered User keff108's Avatar
    Sep 2009
    PA
    Having a huge problem with my bolt on 2013 Wrx. Mods are stage 2 plus EWG and FMIC. Protuned and all that to 340whp and 360wtq. Im having a problem after doing a quick 3rd gear pull last night. Sounds to be a knock but I data logged a few minutes while it was making the sound and didn't see anything out of the ordinary. Its so bad to where I don't want to even drive the car. Sounds like valves are slapping around in the engine. Check the oil with good oil level and still good oil. Im wondering if it could be my transmission or clutch because when I engage the clutch it seems to stop the noise. Its so loud it can be heard over the radio and just is scaring the crap out of me. Im wondering if anyone has had similar issues or anything closely related that might help. Ill link my datalog so you guys can take a look.
    https://docs.google.com/spreadsheet/...rive_web#gid=0
    Any advice or opinions would be greatly appreciated. Im planning on taking it back up to my tuner and I already emailed him about the issue but hoping someone on here has had a similar issue that can shed some light into what it may be. Thanks and happy new year!
    2013 Wrx Black Hatch
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Could be anything, but sounds like a crank bearing. Drain engine oil, see if there's metal bits in it. If no just pour back in and go on.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    What does it sound like at idle in neutral ????
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Registered User MOTION's Avatar
    Oct 2011
    Mandeville, La.
    If it stops when the clutch is in, it's probably the throw out bearing. If it was running fine and just suddenly happened, check your plugs, when iridium plugs detonate a few too many times they explode and pieces bounce around in the cylinder and it sounds JUST like a rod knock.
    Sep 2009
    PA
    At idle in Neutral the sound is still there just not as loud. Gets louder when going about 20-30 mph. I talked to my tuner and sent him the log he said everything looks good and he's thinking it might be something with the trans. I just put new NGK one step colder plugs in Sept. The plugs only have about 1800 miles on them. Setting up and appointment to trailer it to my Tuners shop so he can diagnose the problem. Really hoping its the clutch that way I can jus upgrade it. Well see what he says tho.
    Jul 2013
    Southern NH
    Quote Originally Posted by keff108 View Post
    Sounding more like a pilot bearing, except that would be more of a grind then a knock. Let us know what happens
    Jun 2012
    It really sounds like a throw out bearing issue from your description, but one can never be sure with out inspecting the car in person. Can you list your mods on the car really nice numbers your getting from your rex also this is on pump gas?
    Jul 2013
    Southern NH
    Throw bearing noise occurs when the clutch is engaged not disengaged. OP says quiet when engaged.
    Sep 2009
    PA
    Update: Found out today that I spun a bearing the the bottom end. Motor needs to be replaced or built. Not a very happy camper right now.
    Registered User WREXXY's Avatar
    Oct 2012
    CT
    not to be that guy, but you're at 340whp it was bound to happen eventually
    Registered User wrxnguyen's Avatar
    Jul 2013
    714 Orange County
    Fuh....... what are your plans now?
    Registered User poi88's Avatar
    Feb 2013
    Long Island, NY
    Sorry to hear
    Jul 2013
    Southern NH
    How does the warranty look ????
    Sep 2009
    PA
    I know it was bound to happen sooner or later. Not sure on plans just yet my Mechanic said id be looking at between 7k to 10k for a full motor build. But my problem is that once I go with the built motor Ill need to build the trans which will be even more expensive. All this just isn't what I was expecting this soon. Ive only put 4k miles on it since getting a pro tune.
    My other option which is looking retty good to me is to put the car back to completely stock. I mean every little thing and have it back to 100% stock. Take it in to the dealer and try to get my warranty work done. If I go through all that hassle tho I think I will probably just end up trading it in anyways and getting out of the car. Im not positive whats gonna happen yet tho so we shall play it by ear.
    Jul 2013
    714 Orange County
    What were your specific engine mods if u don't mind me asking.
