2.0 to 2.5
Results 1 to 8 of 8
This is a discussion on 2.0 to 2.5 within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hello start off by saying I got a 03 wrx 2.0t motor spun every connecting rod bearings was going to ...
    Dec 2013
    irwin
    2.0 to 2.5
    hello start off by saying I got a 03 wrx 2.0t motor spun every connecting rod bearings was going to rebuild also has valve with 2 slices in it my question is can I just drop a 2.5 in and if so what mods need done I don't care about boost and power just stock or average just want car to drive have fun and enjoy
    Although there is no such thing as "just drop," the answer is yes. If you need heads too then find an entire motor. If you don't need heads search "hybrid build." Either way you will need to map the ECU, minimum.
    Jun 2013
    Bergen County, NJ
    /facepalm
    2013 STi Sedan
    Pro-tuned by John @ Akuma Motorsports
    Cobb Downpipe
    Cobb Heatshield
    Invidia Q300 CBE
    K&N Drop-in Filter
    DW65c Fuel Pump
    Dec 2013
    irwin
    ok but my main thing is harness and ecm will work just need turned
    Not quite, no. It will depend on how throttle and valve control are done for example . Do you need heads?
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    I have an 03 wagon. I did the Hybrid build with mine a 2.5 sti short block with my 2.0 heads. 850 cc deachwerk injectors, 20g turbo (my vf39 went bad), walboro 255 fuel pump, 44mm tial external wastegate, cobb ebc, full turbo back exhaust and upipe from turbo xs with a tune from turbo xs obviously, sti top mount intercooler (will need to get a turbo xs top mount now for 20g), intake. the full swap for an sti you'll have to get exhaust and intake manifolds, set it up for drive by wire I think (don't quote me on that.) get an sti ecu and a tune. My car now is 336 hp, 335 torque. Just be careful with the manual 5 speed over 300!! Or if you just want stock rebuild it if your comfortable or have someone else do it. Or get a short block and rebuild the heads.
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by nternal View Post
    No. Not even close.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User ronzonothebugeye's Avatar
    Jan 2014
    San Diego
    Quote Originally Posted by scoobaru03 View Post
    Im currently running a vf39, and am thinking of running a 20g, i am also running the pink injectors. my vf39 is starting to smoke.... is the 20g to big, do you think I should run an 18g or 16g. any suggestions. im thinking of rebuildingthe vf39, i may add a new compressor wheel what do you think?
    https://www.xsboostturbochargers.com...f39-vf43-vf48/
    LS stocker to a VTEC rocker!
