Boost creep & aftermarket internal waste-gate actuator
Results 1 to 15 of 17
This is a discussion on Boost creep & aftermarket internal waste-gate actuator within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a 2011 WRX with TP catted DP and AEM Intake tuned by Torqued Performance. I threw P0244 the ...
    Registered User younoleit's Avatar
    May 2012
    I have a 2011 WRX with TP catted DP and AEM Intake tuned by Torqued Performance. I threw P0244 the other night at high/speed RPM. I'd rather avoid the EWG as my car is a daily driver, and someone suggested that I go with the Turbosmart Internal Waste-gate Actuator and GS 3-Port EBCS to fix the problem. Has anyone had experience with this set up? Will the upgraded actuator fix the problem?
    Moderator Donkey's Avatar
    Da boonies,Va
    Probably just need to get the tune re-tweaked a little. The P0244 is just a general overboost code. It is not 100% indicative of a boost creep issue. A datalog would be able to show what the issue is.
    2002 FORESTER S
    1998 FORESTER S
    May 2012
    Eric at TP said it was creep, and that he had tuned it correctly. He says the remaining problem is mechanical and can't be tuned out, but I have had other members of the community suggest an EBCS as a solution.
    Post a datalog
    Resident Tuner @ WTF Tuning
    May 2012
    What is the best way to upload an xcel file?
    Jan 2012
    Philly Area
    Quote Originally Posted by younoleit View Post
    Google docs.
    - Will
    Palmyra, NJ
    ^This. Make sure you make them public.
    May 2012
    I apologize I don't know how to use google docs
    Registered User boone1186's Avatar
    Dec 2011
    Minnesota
    I bet there is a how-to video on YouTube, just trying to help
    2010 WRB WRX
    May 2012
    Try this. This was right before the CEL.
    https://docs.google.com/file/d/0B6nu...N5b09jLWM/edit
    Was there something different that you sent Eric that he determined it to be "boost creep"?
    May 2012
    Mainly throwing the CEL in the given circumstances.
    Did you send that log to Eric before he determined your issue was "boost creep"?
    From your OP, you experienced an overboost code on one occasion. Are you able to replicate the issue? In order to determine that you're experiencing creep vs simple tuning issue, we need to be able to see the information in datalogs.
    Boost creep occurs when the wastegate is unable to bypass enough air to prevent the turbine from building more boost.
    That is not shown in your datalog (your TD Boost Error is <.5PSI from ~3500-6000 RPMs). What you have in your datalog is a ramp up to your maximum boost pressure, a plateau, and then a taper; exactly what you would expect to see with a properly-functioning boost control system.
    May 2012
    I did. While I was never able to "catch it in the act," he said it was creep. Perhaps I have a loose hose? I have taken it into full boost since the incident, however I have not been bold enough to run the higher speed I believe would be required to draw the code.
    The log you posted...did you experience the DTC in the same gear?
