downpipe install
Results 1 to 10 of 10
This is a discussion on downpipe install within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey All, Can anyone tell me if it will be bad for my 02 WRX to install a downpipe before ...
    Registered User bry831's Avatar
    Sep 2013
    Hendersonville, NC
    downpipe install
    Hey All, Can anyone tell me if it will be bad for my 02 WRX to install a downpipe before getting a stage 2 protune? Will be running it for a couple of weeks without the tune.
    Registered User Hogdweeb's Avatar
    Sep 2013
    North Egremont, Massachusetts, United States
    I'm no pro, but I wouldnt. the larger down pipe diameter is going to put more back pressure on your turbo. being a VGT turbo, you cant manually adjust it for the increase. IF you must....keep it from spooling as much as possible to reduce damage.
    May 2007
    orlando flawduh
    02-03 wrxs do not need a tune after installing a downpipe (it's recommended though so you get the most power out of it)
    You'll be fine
    desiree
    downpipe install
    Quote Originally Posted by Hogdweeb View Post
    Larger Φ would decrease back pressure. The bugeye cars are more tolerant anyway. I'd not worry provided that's the only mod and the correct intake remains.
    Sep 2013
    Hendersonville, NC
    Thanks everyone! Next question, will it match up to my OEM mid/cat back without an adapter?
    Sep 2013
    Hendersonville, NC
    Oh, and will I see power gains without before the tune?
    Sep 2013
    Hendersonville, NC
    Stock intake does remain but I do have an invidia up pipe. Nothing else.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by bry831 View Post
    Depends on what the downpipe is.
    Not much without the tune.
    Good call.
    Moderator Donkey's Avatar
    Da boonies,Va
    As Spiros said it will decrease back pressure. And most downpipes either replace the existing covertors with 1 high flow or plain delete them.
    We don't have Variable Geometry Turbos.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2012
    Rocky Top
    It will be fine running it for a few weeks before your tune. Although, you will throw a cat efficiency CEL.
    Which downpipe do you have? You'll likely need an adaptor.
