Ej257/205 Hybrid build questions
Results 1 to 4 of 4
This is a discussion on Ej257/205 Hybrid build questions within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hello everyone! I posted some threads before about my blown engine on my 2003 wrx. I had a few ways ...
    Jan 2013
    Hello everyone! I posted some threads before about my blown engine on my 2003 wrx. I had a few ways of resolving my problem so I have decided to go with a hybrid build. The reason is because I got a good deal on an Ej257 short block. It has a small rod knock but hey - it was $200 . It has under 60k miles and came from a 2008 STI.
    Question: So I am kind of confused about this whole hybrid thing. Some say there is a need to curve into heads in order for them to match STI's combustion chamber. Others say there is no need, or just use a spacer (thicker head gasket) or special Pistons. So which one is it?
    This isn't the only concern about this build. What other things should I look for? What other problems should I expect?
    My budget is really low. I am not looking for anything big for now. I might go with bigger turbo (probably tdo5) bigger injectors, fuel pump, uppipe etc. Thank you for your input!
    Additional Questions: Does an 08 ej257 any different from the previous years? Will my stock wrx mounts work okay? Any additional things to know?
    Moderator Donkey's Avatar
    Da boonies,Va
    No need to redo the combustion chambers on the heads,but they do improve power and driveability. Most just use a thick head gasket to offset the compression ratio.
    2002 FORESTER S
    1998 FORESTER S
            MainFrame's Avatar
    Austin, TX
    If you're on a tight budget, running a thicker head gasket will do just fine.
    Jan 2013
    What size gasket should I use then? and where can I get it?
