JDM EJ205 into 03 USDM WRX??
Results 1 to 6 of 6
This is a discussion on JDM EJ205 into 03 USDM WRX?? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi everyone! I have put a good amount of time in research about my issue here but still didn't find ...
    Jan 2013
    Hi everyone! I have put a good amount of time in research about my issue here but still didn't find a solid answer.
    I have 2003 WRX with all stock ej205. What happened was my turbo decided to go kaboom in the middle of a freeway. After I realized that it might of took out my internals I took the engine apart to see.
    Sure enough I had a hole in piston 4. Also looked like it had a cracked camshaft. Basically a full rebuild is needed, which would cost me no less than 2k. On the other hand I've seen some good JDM ej205 engines for about $1k.
    Let's say a JDM engine will have AVCS - will I need extra wiring or JDM Ecu to work properly?Or will it work with my USDM Ecu? I've seen people say yes and no so I am kind of confused. I am not considering any big power upgrades, so far I just want to go stock and make sure everything will work like it should. And yes I want to be able to pass emissions. I am a student so my budget for this project is minimal. Please help!
            MainFrame's Avatar
    Austin, TX
    Your ECU does not have the hardware to run AVCS.. you would need new wiring AND a new ECU to make AVCS work (and the JDM ECU won't pass emissions). You're better off putting a USDM engine in your car.
    Jan 2013
    Will it mess up my engine if I run it without AVCS on stock ECU?
    Dec 2011
    Quote Originally Posted by elijah.botez View Post
    I'm also looking at getting more info on this subject...
    Dec 2013
    irwin
    looking for info on the jdm motor myself having trouble locating a us motor and also can I use a 2.5 motor and if so what mods do I need and things to perform to work properly oh I got a 03 wrx 2.0 turbo
            MainFrame's Avatar
    Austin, TX
    There are already a lot of threads on hybrid motors.. In fact, I'm running one myself.
