Acessport loosing communication to vehicle
Results 1 to 6 of 6
This is a discussion on Acessport loosing communication to vehicle within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So I have had my acessport for about a year now and have had no problems until now. When I ...
    Registered User SUBIE13WRX's Avatar
    Aug 2013
    Buffalo,NY
    So I have had my acessport for about a year now and have had no problems until now. When I drive normal just using the live data option or data log everything is fine, when I go wot it will read numbers and as soon as I take my foot off the accelerator the ap shows that it has lost communication. Its never done this before untill now. It doesn't matter if its live data or data logging. Has this ever happened to anyone else, if so I'd like some Input thanks.
    2013 Subaru WRX OBP, COBB AP, Stage 2 Pro Tune From Innovative Tuning, Invidia Catless DP, K&N Typhoon Intake, Nameless Perforance Axel Back, 300HP Club!!!
    How often do you have it plugged in? Have you ever kicked the OBDII connection? I've seen damaged OBDII ports from people kicking a cable while plugged in.
    Resident Tuner @ WTF Tuning
    Aug 2013
    Buffalo,NY
    I usally have it plugged in everytime I drive, I never bumbed it atleast I don't think I do, its just weird cause its fine while driving normal but when I get on it it will lose coms
    Suspect faulty wiring or connectors first, bad battery last and least likely.
    Aug 2013
    Buffalo,NY
    Checked the wire didn't see anything broken or bent, cleaned terminals and its still doing it. I guess ill have to call cobb and see what the y think.
    Aug 2013
    Buffalo,NY
    So I finally called cobb and told them what was going on, he told me it sounds like the obd ll plug is going bad cause I have an older v2, and after a while they will start to go bad and cause things like that to happen, looks like ill be upgrading to v3 and ill save $250, not a bad deal!
