Hey guys question about my 2004 wrx air intake system
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
This is a discussion on Hey guys question about my 2004 wrx air intake system within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So when i got my car it had a aftermarket system on it that runs down to the bumper witch ...
    Nov 2013
    So when i got my car it had a aftermarket system on it that runs down to the bumper witch i know its good but i am getting a cobb access port for it and ik cobb said that you need a cobb sf intake witch i plan to get but my question is if i get it can i still install it where my other intake is or could that mess up the maps
    Sent from my DROID RAZR using Tapatalk
    Using Tapatalk
    Sep 2013
    Montrose, CA
    COLD AIR INTAKE REEDIT
    For my own experience, first I bought an INJEN CAI, the ended up buying COBB accesport V3, downloaded Stage 1 into my ECU, but I ended changing the CAI from INJEN to a COBB, because the mapping in the Accesport is designed for the COBB CAI, you should have to replace the actual intake for the COBB brand.... Honestly I didnt feel the difference in Stage 1 map between the 2 different intakes, but i followed suggestions by COBB and from people in this Forum.... all also depends what kind of mods you already have in your car , and if it has been tuned by a professional.
    Hopes this help
    good luck
    May 2007
    orlando flawduh
    This would be a question to ask Cobb.
    Even though their maps are made for certain intakes, the one you have May not skew readings and could potentially be used without causing harm
    desiree
    Nov 2013
    Quote Originally Posted by blusuby View Post
    Hopes this help
    good luck
    I have no clue what kind of intake is on it haven't hot to it yet lol but i have a turbo back exhaust in out so i would like to have stage 2 map
    Using Tapatalk
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    So you're running a stage 2 setup without tuning it? That's pretty stupid. Enjoy blowing your motor.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/...ps665d9b9d.jpg
    Always dirty, never scurred......
    Nov 2013
    Oh it ruins just fine and it has for the last 3 month o think out would have blown by now
    Using Tapatalk
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Bbanks View Post
    And what form of data logging have you used to determine that it "runs fine". I'm assuming you have a WBO2 hooked up as well, since it would be virtually impossible to determine how the car is running without one.
    It has been shown time and time again that 04-05 WRX have a closed loop/open loop fueling delay issue that caused permanent engine damage when running an aftermarket down pipe without tuning. I'm interested to see your logs showing your car runs fine like that opposed to every other 04-05 WRX.
    Just because your engine hasn't blown up doesn't mean you haven't taken 20k miles off of its life expectancy.
    Nov 2013
    Your just a prick y you here if your not even going to help people
    Using Tapatalk
    May 2007
    orlando flawduh
    Hi welcome. Not sure who that was directed towards but either way, name calling is not allowed. Please familiarize yourself with the rules
    Mainframe is 100% correct and his post is helpful. I would highly recommend getting a tune ASAP or returnthe car to stock until you are prepared to tune.
    desiree
    Jul 2012
    Rocky Top
    Maybe you should start listening to tuners, mechanics, more experienced enthusiasts; Mainframe is all of them. If you did your research or listened to anyone at all, then you would know not to run a full TBE without a tune, much less an intake.
    For your original question, only run the intake Cobb says to run if you're using a canned map. If you're getting a protune, then it does not matter what intake you use.
    Nov 2013
    I will listen to then as long as there not rude to me and thank you i will invest on there intake i have the cobb acces port coming do i will look in to Someone to tune out tell i get my cobb intake
    Using Tapatalk
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    Quote Originally Posted by gregroot198521 View Post
    While it may in fact be stupid, there are more effective ways of explaining why that is to a noob. The flame response you provided was more likely to upset and cause butt hurt than to cause someone to stop and think.
    We all know ignorance abounds, especially with noobs and flaming them is usually going to cause them to react to the negative ...which causes them to largely miss your actual point.
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
    Nov 2013
    Ty i agree i Am a noob at this stuff and that's y i joins this place now i will ask this i Am about 100 miles from home would it be a good idea to use a
    different fuel type wile i drive the car home
    Using Tapatalk
    I would use what manufacturer recommends.
    -The J 𒂼𒄄
    Jul 2012
    Rocky Top
    Pretty much everyone says 93 is ideal. But depending on the station and where you're located 91-ish may be the highest grade available. Just don't use 87 lol.
