Engine Help
Results 1 to 9 of 9
This is a discussion on Engine Help within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys so I'm pretty new here an I recently bought a 2003 Wrx(bug eye) so I got the car ...
    Nov 2013
    Engine Help
    Hey guys so I'm pretty new here an I recently bought a 2003 Wrx(bug eye) so I got the car with rod knock an I am now looking for a new bottom end. I contacted Tiger Japanese about a replacement engine an they said that I can use a engine out a 93-98 for just the bottom end. Wondering if I can do this an would there be a difference in gaskets? I would just be using the bottom end.
            MainFrame's Avatar
    Austin, TX
    Don't do it.. I wouldn't consider anything JDM unless you really know what you're doing.
    Moderator Donkey's Avatar
    Da boonies,Va
    Just stick with the stock 02-05 2.0L bottom if you plan on keeping the engine stock.
    2002 FORESTER S
    1998 FORESTER S
    Palmyra, NJ
    Which can be had for as cheap as $500 in good condition if you keep your eye out.
    Nov 2013
    I don't plan on keeping the engine stock. An I can't seem to find any 02-05 bottom ends around. So wondering what I need to get this swap to work?
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Or you could just take the old engine apart and replace parts as needed. Integrate upgrading of crank/rods/pistons as you see fit...
    Nov 2013
    Quote Originally Posted by Ingo View Post
    Old engine is shot has a rod through the block
    Mar 2012
    OK, that's some serious rod knock...
            MainFrame's Avatar
    Austin, TX
    If you're not planning on keeping it stock, then don't waste your money on a stock block.. just go ahead and buy a built block.
