So how much of a difference does this actually make? - Page 2
Results 16 to 30 of 38
This is a discussion on So how much of a difference does this actually make? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by ZXNasty Well first off you will need to be tuned for it. So don't run to the ...
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Quote Originally Posted by ZXNasty View Post
    Well first off you will need to be tuned for it. So don't run to the station and put in E85
    haha come on now, I know that. Just wondering how much of a difference, when tuning time comes, tuning on E85 makes...
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Sep 2013
    Buckeye State
    It makes a big difference. You can't just put it in the tank though. You need larger injectors.
    and what is necessary when tuning on E85 helps too.
    Billy
    Stink-Eye Mob #696
    Facebook
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by McBill View Post
    Dig into some of the build threads on here. There are quite a few people running E85 builds. You can check out what they have done.
  6. #19
    Registered User ZXNasty's Avatar
    Nov 2013
    Murray, KY
    Haha just making sure
  7. #20
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
  8. #21
            MainFrame's Avatar
    Austin, TX
    how much of a difference does tuning on E85 make? as opposed to 93
    Depending on your other mods, about +50whp/+70wtq.. and a good 200rpm (or more) improvement in spool.
  9. #22
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Did someone say E85?
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  10. #23
    Jun 2012
    Boca Raton, FL
    On a stock WRX or STI you can safely run 87 octane fuel. If there is any knocking the boost and timing will be cut back to keep the engine safe. You will likely see less power and perhaps less milage but you are very unlikely to have any engine damage from 87 octane fuel.
    Once the engine is tuned, you do not want to run lower octane then what you are tuned for. The management sensors on the WRX are not very advanced compared to what is being used by GM, Ford and just about everyone else. So if your tuned for 93 octane and running higher the stock boost, 87 octane can cause knocking and the ECU will not be able to correct for it in time to prevent possible engine damage.
  11. #24
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    Quote Originally Posted by Mf645 View Post
    OP take this with a grain of salt. The manual explicitly states to run 91 octane at the minimum. The stock tune is NOT tuned for 87 and could cause engine issues. It is tuned for 91. And yes, running 87 on a 91 tune CAN cause engine failure. For example, at WOT you run a higher risk of engine blowup because the ratios of compression and detonation are different than the tune. Knocking can also lead to unnecessary engine wear or problems when a higher octane would have prevented it in the first place.
    "Safely run 87" is incorrect. Follow the manual.
    Posted from my mobile foruming mah-sheenz
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
  12. #25
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    People don't read their owners manuals? This is news.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
  13. #26
    May 2013
    Riverdale, NJ
    Quote Originally Posted by Drews View Post
    BLASPHEMY!!!
    I'm a build thread?
    Stink-eye Mob #49
  14. #27
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    omg wtf is wrong with people on here nowadays?!
    Just put diesel in it and come back and post results.
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  15. #28
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Actually, I find manuals entertaining. And then there is the occasional "aha"-moment. Like when my windshield washer pump wouldn't work - because I didn't remember which way to use the combination switch (for lack of better word, the one on the right side of the steering wheel)...
  16. #29
    Registered User olenderc's Avatar
    Nov 2012
    CT
    My guess is you should familiarize yourself with the manual and your car first. I mean you've been running 87 octane on a car that clearly requires 91 at a minimum (93 optimally). Before you do anymore damage to your car, learn the car. I wouldn't worry about E85 or tuning whatsoever if you haven't even mastered the basics of opening up your car manual to see what fuel you should be putting into your tank.
  17. #30
    Nov 2010
    Voorhees, NJ
    Quote Originally Posted by olenderc View Post
    I like this bro.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
