TD04 IHI WG adjustment? 05 WRX
Results 1 to 6 of 6
This is a discussion on TD04 IHI WG adjustment? 05 WRX within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have been searching off and on for a few months for an answer but I might not be putting ...
    Nov 2013
    Red face TD04 IHI WG adjustment? 05 WRX
    I have been searching off and on for a few months for an answer but I might not be putting in the right search criteria due to my heavily limited knowledge on the subject so here I am.
    I recently have gone through the process of updating my 05 WRX USDM to stage 2 (full non-catted exhaust, Cobb SF intake, TS BPV and just ordered a new Y-pipe kit. Tuned via the XPT stg2 map ). In the tuning instructions, I was told to adjust my WG actuator arm to attain 16.8psi boost. I have the TD04 IHI turbo which is non adjustable. I've read a lot of good write ups and such but only found one that barely mentioned the IHI being non-adjustable. So, I've been looking for new WG actuator arms and have found a couple but have no idea if they will work for my application.
    Turbo Internal Wastegate Actuator Subaru Impreza WRX TD04L 13T 1 2 Bar | eBay
    I've found cheap td04L turbos on ebay so do I have to go that route? Seems kinda like a waste to not be able to adjust the PSI on a turbo. Read up that it's not a good idea to against tune recommendations like using a mbc(I really don't want to get another tune).
    This has plagued me for quite a while and any help would be greatly appreciated. This might be kind of a dummy question but I want to be thorough.
            MainFrame's Avatar
    Austin, TX
    Where did you get the IHI td04? If it's not the OEM MHI td04l-13t then it's likely that you cannot safely run an OTS stage two map with that turbo anuways.. stage two maps are designed to be used with the stock turbo only. The compressor wheel on a td04l is a little smaller than a standard td04, and there are several varieties.
    I would suspect you're going to need to just get it custom tuned, and the tuner should have no trouble increasing boost via the stock EBCS.
    Nov 2013
    Well, I bought the car about 1.5 yrs ago and the history was kinda sketchy. Maybe the turbo isn't stock at all?
    Moderator Donkey's Avatar
    Da boonies,Va
    There is no such thing as an IHI Td04. IHI uses "VF" nomanclature and MHI uses "Td04/Td05/Td06" nomanclature to designate there models. FYI-The stock turbo for a 05 WRX is a MHI Tdo4l-13T. Stock turbo for a 05 STI is a IHI VF39. Take a picture of the turbo.
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yep, if you have an "IHI" embossed on the compressor housing, that's not the OEM turbo...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Nov 2013
    Cool thanks guys! Sorry for the late reply. Went out of town for eye surgery pre-op and my current phone is terrible for the internet.
    Anywho, this being the wrong turbo might explain why the stock Y-pipe doesn't quite mate up to the turbo properly (falls about 1" short and leaks horribly). My guess is that the original up pipe did crap out and kill the turbo so a shop just put a cheapy mitsubishi turbo in there. I did notice that the uppipe that I removed was in very very clean condition.
    When I removed the uppipe I ended up taking the turbo out and took pictures. Unfortunately, after I put the turbo back in and buttoned it all up, the pics came back terrible but my memory swears I read "td04 IHI" embossed in large letters surrounding the compressor housing face. I'm glad I got this figured out thanks to you guys! I ordered a used td04L on ebay for $160 (won a bid woot!) with ~60k miles on it. Pics look good and the descrip was really good so hopefully this will make my car a lot better. (MOAR POWAH?! maybe??? I hope...)
