Check engine, traction, and blinking cruise
Results 1 to 10 of 10
This is a discussion on Check engine, traction, and blinking cruise within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So, I had this problem the other day and brought it to my autoshop. They reset it with a scanner ...
    Aug 2013
    Madawaska, Maine, United States
    So, I had this problem the other day and brought it to my autoshop. They reset it with a scanner and everything went fine. They said nothing was wrong with the car. 2-3 days later, it happened again. The first time, the problem was emissions leak. Is there something seriously wrong with my car? It's a 13 wrx with 5k miles
    May 2007
    orlando flawduh
    We can't really say unless we know what the code is.
    A small emissions leak is most likely your gas cap not being on tight. The code is po442. If they cleared it but didn't tighten the cap, it probably came back.
    Go to autozone, get the code and report back
    desiree
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    The hamster escaped the turbine wheel!
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  5. #4
    Registered User RichD514's Avatar
    Jun 2012
    Long Island, New York, United States
    Quote Originally Posted by lytlec View Post
    Hate when that happens!
    OP-did you take it to your dealer to get checked?
  6. #5
    Jul 2012
    Rocky Top
    lol,
    No hamster to spin that turbo, no boost. Thaza no good thang.
  7. #6
    Aug 2013
    The code is P0455
    Quote Originally Posted by wrxtreme06 View Post
  8. #7
    Registered User Formula156's Avatar
    Jan 2013
    Orlando
    Remove and reinstall your gas cap drive day or two, if its happen again get a new gas cap ( your warrantee should take care of it).
  9. #8
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Btw no one has mentioned that the CEL traction control and blinking cruise light is your car being in limp mode.
    A car is only as good as its driver
  10. #9
    Registered User dan5505's Avatar
    Sep 2012
    Montana
    If tightening your gas cap doesn't solve the problem, read through this tread: 2013 WRX P0451 Code Evap Emission Control System
    I had P0451, but others reported having P0455. For me, it turned out to be a faulty engine wiring harness. The dealership replaced it under warranty.
  11. #10
    Sep 2012
    Montana
    Here is another case of a faulty engine wiring harness, different codes though: 2012 Misfire P301, P302, P304
