invidia up pipe and grimm speed gaskets
Results 1 to 6 of 6
This is a discussion on invidia up pipe and grimm speed gaskets within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi Folks. Anyone know exactly which grimm speed gaskets are needed for an up pipe replace? And are the permaseal ...
    Registered User bry831's Avatar
    Sep 2013
    Hendersonville, NC
    Hi Folks. Anyone know exactly which grimm speed gaskets are needed for an up pipe replace? And are the permaseal gaskets just as good? Thanks for any help!
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    what year is your car?
    Sep 2013
    Hendersonville, NC
    It's an 02 completely stock, for now.
    Nov 2012
    I don't have any experience with an 02, but check this out Uppipe, Downpipe, Muffler INSTALL GUIDE!
    Registered User super_usdm's Avatar
    Jul 2012
    Sacramento, CA
    Yea you need the one that goes from manifold to UP (2 bolt) and the one that goes from UP to turbo (4 bolt). I wouldnt use permaseal. I recommend using OEM gaskets.
    Any broken exhaust seal will require a new gasket. It depends on your install method, but the following three are always needed:
    1) Downpipe/turbo
    2) Uppipe/turbo
    3) Uppipe/manifold
    If you pull the turbo, just those three are needed. If you drop the exhaust manifold, you'll need further gaskets. If you just remove the passenger manifold elbow, you'd need a manifold/crosspipe gasket. If you drop the entire manifold, you'll need two manifold/head gaskets. If your downpipe uses a donut gasket (e.g., stock), you may be able to reuse that as it doesn't have a lip like a flat gasket. If your downpipe/catback uses a 3" flat gasket, that will need to be replaced as well.
    I always use OE gaskets, when available. In the case that they're not available (e.g., 3" flat flange gaskets on the catback/downpipe), I use Grimmspeed.
    Resident Tuner @ WTF Tuning
