Uppipe Question
Results 1 to 15 of 21
This is a discussion on Uppipe Question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ok so I have a 04 WRX... I wanna replace the UP because I have been told that they are ...
    Registered User ClosetSubyLover's Avatar
    Apr 2013
    Planet Earth
    Uppipe Question
    Ok so I have a 04 WRX... I wanna replace the UP because I have been told that they are catted and can break down and cause all those yummies to go into your turbo(Correct me if Im wrong on that).
    I was looking around on RallyDirect and in the description for one of the GrimmSpeed Uppipes, they claimed an extra +10whp and also claimed it was one of the best $/Hp gain ratios you could do to your car. I guess that leads me to a few questions...
    1. Is this true for the extra +10whp?
    2. I have the COBB AP Stage 2 93 tune so am I have gonna have to get it protuned to see any of that extra whp? Or is it just gonna "adapt" so to speak and just free up a couple extra ponys?
            MainFrame's Avatar
    Austin, TX
    +10whp is pretty generous. The turbo will spool better, and you will gain some power, maybe more like 5whp realistically. Your AP stage 2 tune should be fine, I would reset the ECU and then log a day or two after the swap just to be safe.
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    If you can find a stock UP off a newer model they have catless UPs and would save you a couple bucks.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    i did the grimmspeed up pipe and new top mount mishimoto intercooler hoses on my 02. turbo spools much smoother and at a lower rpm than when i bought it. boost gauge says i am making low boost numbers by 2200rpm now verses 2700ish before. maybe not to much more power over all...just sooner. my idle seems a bit smoother to and sits rock solid at 500 rpm.
    edit. after re-reading, i am not tuned yet, still running the factory ecu and everything has been ok.
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    Apr 2013
    Planet Earth
    OK guys I appreciate the advice I think I know what Im looking for now!
    Quote Originally Posted by ClosetSubyLover
    Quote Originally Posted by MainFrame
    10whp peak or 10whp at points in the RPM band?
    Resident Tuner @ WTF Tuning
            MainFrame's Avatar
    Austin, TX
    right.. I wouldn't be too surprised to see a 10whp gain around 3500rpm, but not at 5500rpm
    Apr 2013
    Planet Earth
    So a couple more things to ask...
    I guess replacing a catted UP for a catless will cause a CEL? but what if its tuned?
    Am I gonna go have to buy that 2.2Kohm resistor people are talking about? and plug it into my EGT sensor?
    I know mainframe said it should be ok and just double checking by logging but no word from anyone on a CEL from the install.
    Quote Originally Posted by ClosetSubyLover View Post
    It should, yes.
    "Tuning" refers to altering the base mapping, for better or worse. Since there is access to the ECU, the CEL can be eliminated and hopefully the sensor can be switched to a "ready" state.
    Not necessarily; see above.
    Registered User Dzanga's Avatar
    Oct 2011
    phx
    Quote Originally Posted by Drews View Post
    I have a up pipe off my 13 if anybody would be interested.
    2012 Wrx SWP Hatch-Traded
    2013 Limited ISM Hatch -Current
    Apr 2013
    Planet Earth
    Can you elaborate on this a little more? Considering you said I might not necessarily have to get a resistor.... I is confuzzled
    If the CEL is addressed electronically you won't need a resistor. If it is not, you will.
    Aug 2012
    Up-pipe wont cause a cell if it has proper placement of the senser and a place to put it.. Otherwise it will throw a cell and you have to get a fix for the sensor that plugs into it.
    I have GT-spec up-pipe.. With OE sensor installed.. NO cells 2 years going
    Aug 2012
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by Dat8687 View Post
    CEL* and sensor* Your posts can be pretty painful to read.
