Just installed FMS FMIC Questions
Results 1 to 15 of 15
This is a discussion on Just installed FMS FMIC Questions within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; As the title states I just installed my FMS FMIC on my 2013 wrx. Everything fits well and looks good. ...
    Registered User keff108's Avatar
    Sep 2009
    PA
    As the title states I just installed my FMS FMIC on my 2013 wrx. Everything fits well and looks good. Took the car out for a quick drive to make sure no leaks and I blew the stock throttle body pipe off fairly quickly. Threw that back on and made sure to snug it alot tighter then it was before. Everything runs fine now but there is a faint whistle sound like a leak. My question is for anyone who has this FMIC or helped someone install one. Did you do anything to the stock throttle body pipe such as I read that you need to take the end caps off or something along those lines. I already ordered a Gimmick Motorsports throttle body pipe but that wont be in for a week. Im just trying to do something to stop the whistle sound and something to hold me over until the new one comes in. Is there anything I could do to check for leaks in the piping along the couplings.
    2013 Wrx Black Hatch
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Let's just slap parts on cars without tuning!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2009
    PA
    Thanks for the helpful response.
    stage 3 tuned by Eric at Torqued Performance.
    zax
    zax is offline
    Nov 2008
    So what did Eric say when you asked him this question?
    Facebook me here
    Registered User WrxPower's Avatar
    Mar 2012
    Florida
    So your not sure where the whistle is coming from?
    Sep 2009
    PA
    Not 100% sure but it sounds like the drivers side which is where the throttle body hose is located. Im honestly thinking its that but obviously not sure. Ive gone through a checked all other clamps and everything is lined up correctly and tightened.
    Mar 2012
    Florida
    My body installed this on his 12 Wrx. I know be was having a issue with his bov. I will let him know about this thread and see if he can chime in.
    Jun 2012
    clermont FL
    I had 2 leaks when I first did mine, one off the turbo and one at the coupler that is right next to the stock coolant overflow. I did not use the stock throttle body hose on mine though, sounds to me like that's all it is though. You can build a boost leak detector if you happen to have an air compressor to use though, just search for it on the forums. Really easy and cheap to build one
    Sep 2009
    PA
    I wonder if that would be my issue. Im running a Turbosmart plumb BPV. Im wondering if hes running the same. Im also running an external wastegate but I doubt thats having any play in this.
    You could even use a bicycle pump to inflate the boost detector if you decide to put one together.
    Sep 2009
    PA
    Thanks for the responses. Just checked and my new throttle body hose will be in on Wednesday. Do you guys think I can make it til then babying the car and staying out of boost. Probably will only drive to and from work. 15 miles highway each way.
    I need a daily I know haha
    Jun 2012
    clermont FL
    If its just a small leak I wouldn't think it would be that big of a deal if you drive it lightly. Will just run rich. I would reset the ecu once you get the new throttle body hose thiugh
    Sep 2009
    PA
    Thanks for the help guys!
    zax
    zax is offline
    Nov 2008
    Bump.
    Seriously. You have a tuner. Why not ask his advice? Furthermore, if you suspect a vac leak or a boost leak, the first thing I'd do is pull up your LV and/or datalog.
    Facebook me here
    Sep 2009
    PA
    zax
    Was waiting for tuner to reply. He suggested changing the stock clamp to a t-bolt clamp. I had one extra from the FMIC install and threw it on. Seems to not have changed anything. Just gonna wait til I get the new throttle body hose and build myself a boost leak tester. Im pretty sure the throttle body hose is my problem.
