Problem installing Turbo Inlet on 04 WRX...Please Help!
Results 1 to 3 of 3
This is a discussion on Problem installing Turbo Inlet on 04 WRX...Please Help! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hello All I have an 04 WRX and the Turbo Inlet Pipe was cracked so I bought an aftermarket silicone ...
    Mar 2013
    MA
    Hello All
    I have an 04 WRX and the Turbo Inlet Pipe was cracked so I bought an aftermarket silicone one to replace it. Now besides the stupid issues of vacuum lines and the plastic fitting being brittle and braking I have one Major Issue. One the 04 WRX and I assume newer since it was first introduced on the 04, there is what seems to be a Pressure Sensor that was connected Directly to the original Turbo Inlet. It slid directly into one of the plastic fittings on the inlet, how ever the new inlet has metal hose fittings and does not slid into it / around it like the old one. Has anyone else run into this issue and could they Please help me out in coming up with a viable solution that will work. I have read another post on NASIOC that someone had the same issue but the suggestions there were to just bypass it because they didn't know what it did and it didn't seem to set off the CEL. I would rather not do this and keep it the way it was so if anyone has had this issue and actually found a solution, Please Help. Link to the NASIOC post is below...
    Difficulty with Perrin Turbo Inlet Hose on a 2004 WRX? - NASIOC
    Thank You All in advance for your Help!
    Oct 2011
    Santa Ana, CA
    The little sensor near the turbo? The PCV sensor? It does next to nothing. Take it off the hose but leave it plugged in.
    Route the PCV hose into the new hole on the inlet. You'll need some fittings.
    Mar 2013
    MA
    Thank You very much UEDan for your quick response. Actually after I made this post on this site I moved to another and actually found a link to the Perrin Installation Instructions online, and you are exactly right. In case anyone else runs into the same issue I had below is the link to the Perrin Installation Instructions which give a great detailed description and diagrams of what needs to be done so there is no issues.
    http://www.perrinperformance.com/sha.../pspint400.pdf
