airflow over the down pipe idea.
Results 1 to 11 of 11
This is a discussion on airflow over the down pipe idea. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; actually, not my idea. that said, i was changing oil on a 08 mercury milan 4cylinder and noticed a out ...
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    actually, not my idea. that said, i was changing oil on a 08 mercury milan 4cylinder and noticed a out of place plactic tube runnning from the top of the cooling fan to the back of the motor. well, where do you go? right over the heat shield for the top most cat. takes air from the electric fan and pumps it right down the downpipe.
    i can think of doing this two ways. mod a existing piece(probably from the same vehicle...ive never seen another that i can remember pre wrx anyway) or install a small 12v fan in the space between timc and right strut tower. i have a bit of room running factory turbo/timc. around town i can see that helping push under hood temps down, but the hot side of the turbo needs to stay hot right? like blanket and shield hot? so the forced air would have to be routed past the turbo and pointed down the back side of the downpipe.
    course, this could be solved with a ceramic coated and wrapped grimmspeed downpipe, which is on the list of course. just chewing on ideas whilst working away.
    There were both commercial and DIY turbo chimneys for that area intended to funnel heat up and away. I've not seen one in years. Fans had been tried by a couple posters way back, but the effects are apparently not noteworthy enough to remember. Sounds interesting though.
    Registered User silvercookie's Avatar
    Aug 2009
    Glendale, NY
    Would be better off just putting 2 or 3 fans directly onto the tmic itself.
    I don't think so. Fans haven't proven as effective as simply tilting the IC, for example.
    Nov 2012
    Aah...the blarg mod. Done lol. One of my first mods actually. I was thinking the fan thing since I have a 8" 500cfm left over from a atomic cooler used to cool the gas line on my old camaro. Kept the corn gas from boiling and causing my carb to choke. I think the hole unit is too big for a oil cooler but the fan is removable. All I would need is to fan mount and a airflow splitter. That way I get hot out behind and down the exhaust and could push some sideways under the timic and out.
    Or...I could get some sleep. Lol *yawn*
    I did some rough math and if I'm not wrong 500 cfm is the equivalent of low speed motion in a parking lot or stop and go traffic. If there is a routine speed above which that airflow is exceeded then the fan will be at most ineffective, at worst an obstacle.
    What I did was assume the frontal area is one ft wide by one ft high, then converted 500 linear ft per minute to kph of vehicle speed.
    I think the car quickly exceeds the speed at which a fan is useful. I could be wrong though.
    Palmyra, NJ
    A fan placed over the intercooler would effectively block the intercooler more than it helps...same as when people put chicken wire screens or Grillecraft screens in their scoops thinking it will help.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Exactly what are you attempting to accomplish here? Heat retained in the Turbo and Downpipe region is GOOD for flow! You do not want to cool the exhaust gas as the gas will become less energetic and the velocity will decrease.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    zax
    zax is offline
    Nov 2008
    I had a similar issue a few years ago: my Bike (air Cooled Harley Evolution motor) would get too hot in stop-and-go traffic during hot days (30+ degrees C) causing detonation. Buell uses a fan to force-cool the motor as well as piston oil squirters and an oil cooler. In an effort to reduce heat in traffic conditions, I was working on a fan rig that would draw air through the oil cooler even when the bike was stationary. However, even the most efficient fans (read: expensive) would only draw air at a rate that was equivalent to the bike moving at 15mph. Furthermore, this obstruction would cause a 15% drop in flow efficiency at 60mph per my calculation, so I ultimately scratched the project.
    Facebook me here
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    OP, if you get under your car and look up, you will see the bottom of the IC and the down pipe. As far of aero goes, there are a couple things in play. Air flows into the scoop, through the splitter and blows onto the DP and through the IC. Also as the car moves, a low pressure area is created underneith the car, causing a vacuum that draws air out of the engine compartment, along the bottom of the floor, and out the back of the car.
    This is why all manner of fans and things have been a rather mute point.
    Now the "Turbo chimney mod" was actually meant to do two things:
    1. Act as an additional heat shield to save the IC from being heat soaked on that one side.
    2. Create a "nozzle effect" and focus higher pressure air over the down pipe to improve the natural savaging effect.
    Problem with the turbo chimney is that if the ambient is below the 90's, or the car is moving above 20MPH, it doesn't really do anything.
    The "IC halos" which spray CO2 over the IC's are nice, except that the IAT sensor on the stock WRX is not between the IC and TB causing erroneous readings and potential errors.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jan 2012
    New Jersey
    from a forester forum
    CFLip2x 2012 WRB WRX Build
