Difference in exhaust??
Results 1 to 15 of 23
This is a discussion on Difference in exhaust?? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I was looking to have my wrx taking to a shop to have stage 2 and tune done. They gave ...
    Registered User bhunt41's Avatar
    Apr 2013
    Selinsgrove, pa
    I was looking to have my wrx taking to a shop to have stage 2 and tune done. They gave me quotes for what they use the most on subarus. What is the difference if any between turboxs and invidia exhaust wise? And is it better to have catted down pipe or non catted? Now with intake which is better aem or cobb? I've seen all these names and prices every where but I don't know what to choose.
    Palmyra, NJ
    What are your emissions laws in PA? (probably wouldn't pass a visual unless you know the shop, if you do go Catless)
    Your exhausts all do the same thing...expel gasses. Downpipes all do the same thing. Catted and catless are only a difference of cost, as well as legal or not. Performance won't really be different at all.
    Figure out what you want to spend, and go from there. What shop are you looking at?
    AEM intake is generally considered a bit better because it's further away from the engine, so less heat intake. But if you have the airbox with the Cobb SF, it's probably alright as well.
    Apr 2013
    Selinsgrove, pa
    The county I live in has no emissions and plus I have my inspection license so inspections aren't a worry to me. But between turboxs and invidia they are the same basically? The only thing I know matters is intake. It depends on what flow more air correct?
    Palmyra, NJ
    They are both 3in exhausts and will all flow the same. Invidia and TurboXS are both known as good reputable brands...so there is literally no difference other than name and price. Comes down to personal preference on looks, sound, and price at that point.
    Jan 2009
    Md
    you will make more noise and gain no power except for the DP... there you go
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    MOAR NOISE
    Apr 2013
    Selinsgrove, pa
    My only other question is if I choose one brand of cat back do I need to match it to the same brand down pipe?
    Nov 2012
    Quote Originally Posted by bhunt41 View Post
    No.
    Apr 2013
    Selinsgrove, pa
    Any one know of a place with exhaust gaskets? I found an invidia cat back for my wrx but they done have the gaskets that come with it. Any one have an idea on where or what I could do to find some or made something for?
    Nov 2012
    Your nearest subaru dealership.
    Invidia places their cat close to the turbo, while TurboXS places their cat closer to the catback. The closer to the turbo, the more "restrictive" it is, as well as the better at "cleaning" the exhaust gases. Also, if your car has a tendency to boost creep, a cat closer to the turbo is better able to combat that. On a S2 car, there will be pretty negligible differences in terms of spool/response.
    Personally, I'd go TurboXS and if an issue arose with boost creep, just go EWG (the proper remedy vs a HFC). Since Invidia uses a divided wastegate design, I'd prefer the bellmouth offering if I went EWG (bellmouth on the Invidia is only offered in their catless version).
    If going catless, either one would be a solid choice, and I'd say go with the one that's cheaper.
    Resident Tuner @ WTF Tuning
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    In my experience,yes. I had a Cobb DP. Decided to go with an Invidia Catback & they hardly mated. The design was different.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Quote Originally Posted by rage-wrx
    Different flanges, so somewhat of an apples/oranges comparison. Having quality components at both ends, if the flange matches, you shouldn't have an issue...
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    My local NAPA shop had a full set of gaskets from engine to axleback. The dealer will have them too.
    2007 Outback 3.0R wagon
    Aug 2010
    Yonkers/NYC
    For me the cat on the Q300 midpipe was hitting the chassis. & I Couldn't get the flanges to line up properly without a gap & there was a leak. I had no issues with the GReddy though. The cat was a lot smaller & it lined up perfectly.
    I would think this would be more of an issue with hatchbacks than sedans since different manufacturers use vastly different designs for the midpipe.
    BTW the Invidia catback only uses flat gaskets. Should be available at any local auto store.
    T0ny
    2011 WRX
    2012 FXT
