Engine help: major under boost
Closed Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
This is a discussion on Engine help: major under boost within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I logged my car today to see how stage 1 was going. I have a 2011 wrx sedan. From 2k ...
    Registered User ElusiveSAV's Avatar
    Jun 2013
    PA
    Exclamation Engine help: major under boost
    I logged my car today to see how stage 1 was going. I have a 2011 wrx sedan. From 2k Rpms till 6100 Rpms I'm only getting 9lbs of boost. Target is 13-17. Tried running the high wastegate map and it did not help at all. All signs lead to boost leaks? Where should I look? I bought the car used. I don't believe there is any other work done. The downpipe still says Subaru on it. I would post my logs but I don't have Internet only my phone. All other readings are good DAM = 1, fine knock learn = 0. Could I be logging wrong? I was in 3rd and went from 2k till 7. 100% throttle. Wastegate duty readings are ranging from 65-71. Never was I even close to target boost. Help plz!
    Quick reply to this message Reply
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Is it a cobb map? Any mods other than the flash? If I were you I would flash to stock and see how it runs on stock.
    Jun 2013
    PA
    Just uninstall it and log it?
    Jun 2013
    PA
    Yes Cobb map. Nothing else done that I know of.
    Boost leak (check the TMIC/TB coupler)
    Boost control solenoid
    Resident Tuner @ WTF Tuning
    Jun 2013
    PA
    How do I check it? See if its pushing air out?
    Registered User Liquid2k's Avatar
    Apr 2012
    Ottawa, ON
    Sounds like you're reading wastegate spring pressure... If you want an informative thread on how boost works on our cars, check out this link from cobb: https://cobbtuning.zendesk.com/entri...l-System-Works
    Also, here is a flow chart that you may find useful for troubleshooting your problem:
    My buddy just had the same issue with his STi, result was a missing restrictor pill in one of the lines from the BCS. I highly doubt flashing to stock will yield any helpful results.
    Jun 2013
    PA
    So best way to combat the problem would be what?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    From where did that flowchart come?! I would absolutely NOT disconnect the wastegate plumbing to see if the boost spikes. This could easily blow the motor for a number of reasons: 1.) compressor outlet temps will be much higher if run out of efficiency... resulting in increased predet 2.) untuned boost pressures may put the car into untuned load cells, thus putting the spark event after the det line. Either situation will cause irreparable damage to the motor.
    If you suspect the solenoid, remove the solenoid and check the resistance on the test pins. Or, even simpler, put the car into test mode and listen for the solenoid to click.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Apr 2012
    Ottawa, ON
    I found the flowchart on another STi forum while searching for a solution to a friends problem. I completely agree with the dangers of disconnecting the wastegate line for a prolonged period, however, would you suggest it is still as dangerous for use in a very short duration? When I spoke with a Subaru tech about the issue, he said it would help to eliminate potential causes.. but warned that if boost levels were approaching target, to keep out of boost until returning home.
    .. Your input is appreciated Zax, so that I do not pass this information on if it is incorrect or dangerous...
    zax
    zax is offline
    Nov 2008
    IMO it's too easy to boost to dangerous levels.
    Facebook me here
    Jun 2013
    PA
    Problem found. Previous owner had a EBC. Replaced with wrong lines and didn't hook some up. Thanks for your help! This should fix my problems. Vacuum lines from wastegate to turbo.
    Aug 2012
    Alexandria, VA
    I just put an EBCS on my '13 this past weekend too. Made sure I followed each line from the unit to the correct connecting device. Very easy to pinch a hose with the angles. Glad to see you figured it out on your own.
    Jun 2013
    PA
    I had help from turbotec ray and Zax. Couldn't have done it without the help of this forum!
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Liquid2k View Post
    ..would you suggest it is still as dangerous for use in a very short duration?
    A single uncontrolled overboost like that could easily kill the motor, turbo, or both.
Closed Thread
