AVO Intercooler Installed - Strange sound when starting engine
Results 1 to 8 of 8
This is a discussion on AVO Intercooler Installed - Strange sound when starting engine within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Thought I throw this one out to the tuner guys. I finished installing a new AVO Intercooler on my '13 ...
    Aug 2012
    Alexandria, VA
    Thought I throw this one out to the tuner guys. I finished installing a new AVO Intercooler on my '13 WRX, replaced the factory unit. Everything bolted up well and my new throttlebody hose I was using my stock intercooler sealed tight with the T-clamps, so no issues there. Started the car and checked for leaks and all looks and sounds good.
    Issue, when I turn the engine over now I get a hollow cranking sound almost like there is a hole in the firewall and I can hear inside the starter motor as it's turning. The car does fire right up and maybe even a little quicker, could be my imagination though. Is the sound from the new intercooler being bigger and all aluminum creating the engine start sound echo? Once the engine is started and running everything else sounds normal. Footnote, I did swap out my stock "pitch stop" for a Kartboy Pitch Stop but don't think that would cause a different engine starting sound in the cabin.
    Any help is as always appreciated.
    Dec 2011
    Pottstown PA
    its your pitch stop not the intercooler. im installing a new TMIC very soon and got a Perrin pitch stop to install so im anxious to hear how it sounds.
    also how did you check for leaks?
    Marky Mark
    My bugeye build
    MinoskePhotography
    Aug 2012
    Alexandria, VA
    Quote Originally Posted by Ruh Roh View Post
    Hmmm, I guess it could be NVH from the pitch stop but I didn't expect that on a startup. For the leak check I did a visual check for leaks and water spray on all connections and around the intercooler itself while engine was running. The only item I really notice from the pitch stop install was running the car in second gear you can hear the trans vibration whereas before nothing.
    Dec 2011
    Pottstown PA
    yep that was one of the things ive been told gets louder. ah ok yea on my bugeye im pressurizing the turbo inlet to check for leaks, tmic because it did leak and just got new gaskets, but you have a 2013 so you should be fine lol
    Marky Mark
    My bugeye build
    MinoskePhotography
    Palmyra, NJ
    Pitch Stop. It's connects the tranny and firewall...starter is attached to the transmission...only makes sense, right?
    Dec 2011
    Pottstown PA
    no mikie, not at all. Who told you about this witchcraft?
    Marky Mark
    My bugeye build
    MinoskePhotography
    Aug 2012
    Alexandria, VA
    I was pleased to see my stock intercooler when removed after 5,000 miles was bone dry, not a hint of blow-by on the inlet. Getting a dyno tune on the 22nd and I will ask Dan to look the engine bay over for any issues. Big week of changes, Kartboy shifter bushings, intercooler, pitch stop, and tomorrow EBCS (have a tune from TP to run with it until the Pro Tune).
    Dec 2011
    Pottstown PA
    Quote Originally Posted by Delnari View Post
    Nice nice. Yea I'm kinda in the same situation as you lol. I have no blow by but I have a catch can in the cyclinder head vent line. Just installed my pitch stop with no noticeable cabin noise...kinda wanted some lol. Just installed tmic as well and doesn't leak recently installed ebcs and mbc and currently getting e-tuned.
    What ebcs did you get? Talk to the tuner about a hybrid setup? Look in my signature for more info on that and talk to your tuner
    Marky Mark
    My bugeye build
    MinoskePhotography
