Downpipe and Tune...is that all?
Results 1 to 14 of 14
This is a discussion on Downpipe and Tune...is that all? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hello everyone! First and foremost, I drive a 2012 WRB WRX with just a Kartboy SS and front/rear bushings installed, ...
    Registered User SubieDoo0531's Avatar
    Nov 2012
    New York
    Hello everyone!
    First and foremost, I drive a 2012 WRB WRX with just a Kartboy SS and front/rear bushings installed, all else is stock.
    As the title of the thread suggests, I'm in the market for a downpipe. I'm aware that the replacement of my stock downpipe with an aftermarket one will require a tune. I plan to go OS with a Torqued Performance Stage 2 setup.
    However, I'm wondering if there are any other parts I'd need or want for the installation of the aftermarket downpipe. I plan to go with a Divorced Invidia Catted downpipe. Any information/input would be greatly appreciated.
    Thanks in advance!
    Steve
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    If going TP Stage 2 I would ask them!
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Nov 2012
    New York
    Quote Originally Posted by lytlec View Post
    I meant something like an adapter for the downpipe to the stock catback, or turbo to downpipe gasket.
    Along the lines of:
    GrimmSpeed 3in Downpipe to Stock Cat-Back Adapter Subaru Turbo Models 077044 at RallySportDirect.com
    Permaseal MLS-R Turbo to Downpipe Gasket Subaru Turbo Models TUR010 at RallySportDirect.com
    Just wondering if they were necessary in order to achieve proper installation.
  5. #4
    iH4
    iH4 is offline
    Registered User iH4's Avatar
    Apr 2013
    the OC
    First time I hear of Torque Performance unfortunately... after checking out their site, I doesn't seem like you'll anything else other than the downpipe to go to Stage 2. Same as Cobb.
    Time for AWD fun! CBS 2013 WRX Sedan - SoCal - OC
  6. #5
    Registered User risko's Avatar
    Dec 2012
    Logan, Utah
    Yes, you'll need the grimmspeed adapter to properly attach the 3" downpipe to the stock catback. Should also get a new donut gasket.
  7. #6
    Nov 2012
    New York
    Quote Originally Posted by risko View Post
    Awesome I really appreciate your help!
  8. #7
    iH4
    iH4 is offline
    Apr 2013
    the OC
    I like the Cobb for the reason that its a direct bolt-on to stock exhaust. Only thing you need with theirs is the heat shield so you don't have to cut away at stock one.
  9. #8
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You'll also want some PB blaster to spray on the bolts to help get them loose. If you are ever thinking about being able to accurately monitor air/fuel ratio, a wideband o2 sensor is a great investment, and when changing out the downpipe, this is a great time to install that...Just a thought
    If you don't have a boost gauge, the AP can be used to monitor your boost (and all other data obviously), so it is helpful to have a method of mounting it. Otherwise, a boost gauge is a good investment as well.
  10. #9
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    - breaker bar
    - good clean 6 point socket for the DP bolts on the turbo
    - adapter to attach the 3" DP to the 2.5" OEM catback
    - possibly new bolts to connect DP to CB (your DP may come with some)
    - new heat shield or cut yours (diy's are out there for this)
    - very cold beer, very!
  11. #10
    Nov 2012
    New York
    Quote Originally Posted by MercRising View Post
    - breaker bar
    A lighter or darker beer? I need to get this just right
  12. #11
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I agree with the heatshield comment. You will need a new aftermarket one or cut the stock shield.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  13. #12
    Nov 2012
    New York
    Quote Originally Posted by rage-wrx View Post
    Does it pay to purchase a new heat shield, or will cutting the stock heat shield suffice?
  14. #13
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by SubieDoo0531 View Post
    When wrenching I usually go with a ****ty light American beer.. although that's mostly because I live in TX and it's hot as bawlz here.
    The stock heat shield is fine, and trimming it is easy.
  15. #14
    iH4
    iH4 is offline
    Apr 2013
    the OC
    But if you ever need to go back to stock, you don't need able to use it again.
