secondary air pump delete
Results 1 to 4 of 4
This is a discussion on secondary air pump delete within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm removing the secondary air pump on my 2011 wrx. Got the pump out and drivers side valve. ...
    Registered User teddy37's Avatar
    May 2010
    Garrett County Maryland
    Hey guys I'm removing the secondary air pump on my 2011 wrx. Got the pump out and drivers side valve. But Im trying to install the block off plate and it seems the stock bolts are about a 1/4'' to long with the block off plate. Im guessing you have to buy shorter bolts to install the plates? Last thing I wanna do is over tighten the bolt and break it off in the block.
    2011 Wrx DGM TP Stage 3
    Stink-eye mob #3737
    Registered User wrx50's Avatar
    Jun 2012
    MA
    Could always use some washers to make up the difference if you don't have any bolts lying around. Temporary of course if it bothers you. Why are you removing it anyway? What's the benefit?
    May 2010
    I was considering that. Think i actually might
    have some the right size too.
    Stink-eye mob #3737
    May 2010
    Just more space is all. Weighs close to 10 lbs I'd say
    Stink-eye mob #3737
