Stage 1 Upgrade - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Stage 1 Upgrade within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; ??...
    Registered User ElusiveSAV's Avatar
    Jun 2013
    PA
    Quote Originally Posted by ElusiveSAV
    What are you unsure of?
    Resident Tuner @ WTF Tuning
    Jun 2013
    PA
    If its normal to have to turn up the idle slightly when you go stage 1. Read prior posts it will explain
  6. #19
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    No, it's not normal.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  7. #20
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by SubiEj255 View Post
    I'm still not sure what you mean.
    I think he means that from stock idle the car stumbles slightly when revving the engine.
    Quote Originally Posted by ElusiveSAV View Post
    Can that be adjusted with the ap? and at idle when it was set at 750 if I gave the gas a little tap to slightly rev it would wanna stall. Aka the Rpms went down for a quick second. So I adjusted about 50 Rpms and now it's perfect.
    The tip-in enrichment tables are basically for tuning in extra fuel compensations under specific conditions where there are abrupt changes in throttle opening angle over a certain percentage. It is not "normal" to have to need to increase idle engine speed to prevent stumbling on a stage one tune, but what you're running is a one size fits all base map anyways, so it's not really tailored to your car. It's pretty hard to really tell what's going on without a WBO2 installed to log, but you could always try lowering your idle back to where it was and increasing your tip-in by about 40ms and see if it's better or worse, then decrease it by the same amount and try again. check over the logs carefully and see if one or the other increases low load knock events. If so that's a bad thing and you want to head in the other direction.
    For what it's worth, my warm idle speed is set at 1000rpm..
  8. #21
    Jun 2013
    PA
    Ill log it tonight and post the logs on here. My warm idle is like 800. Can I adjust what you recommended with the ap?
  9. #22
            MainFrame's Avatar
    Austin, TX
    Yes, in Accesstuner Race you should be able to adjust it. You might want to hunt around for vacuum leaks first tho.
  10. #23
    You shouldn't be modifying anything that you don't understand.
