I dont know what engine will work!
Results 1 to 12 of 12
This is a discussion on I dont know what engine will work! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I recently purchased a 2002 WRX Wagon without an engine or transmission. I am looking to purchase both and make ...
    Jun 2013
    I am looking to purchase both and make a fun little car!
    I see a lot of engines for sale on the electronic bay dot com - EJ20 2.0 DOHC Turbo - but they arent necesarily for my year. I need to know which engines will work with my car and wire harness. I dont mind doing some work. If i got an engine from a 1996 WRX would i be able to make it work without much issue?
    There is also an engine or two that i have seen that say 1999-2005 but i dont think that is a year range when where the engines were the same..
    what do you guys think? I am new to the WRX world. This is my first one
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Are you wanting to put the stock engine back in or do a full engine swap?
    Also are you in the US?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Jun 2013
    I dont mind doing some work but im looking at my most affordable option and i think that would be the stock engine. I think that would be the easiest option as well?
    I am in the US
    Nov 2011
    North GA
    Yeah putting a stock engine/trans will be the easiest option by far. Does the car already have the stock wiring harness/ecu?
    If so you can look for an EJ205 these can come from any 2002-2005 WRX. I would recommend trying to find a BA trans to match. The AA trans is said to be a little weaker.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jun 2013
    So years other than that wont work? Would i have to change out the ECU and wiring harness?
    Nov 2011
    North GA
    Subaru changed engines in 2006 to a 2.5 liter. You can certainly use one of those if you wanted but, you will have to change wiring harness/ecu and the differentials I believe.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jun 2013
    how about years like mid 90s
    Nov 2011
    North GA
    The US didn't get the WRX until 2002 so anything before then would mean changing pretty much everything.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jun 2013
    Also - what about JDM engines?
    Nov 2011
    North GA
    Well technically every WRX engine is JDM because Subaru builds all their cars in Japan.
    I think what you mean is Japanese spec engines like EJ207 then that would also require modification.
    Basically anything other than a EJ205 will need modifying. It will not be plug and play.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Jun 2013
    insteresting - ok thank you good sir!
    Palmyra, NJ
    Yes, the stock engine would be the easiest. You COULD do a Hybrid with any 2.5L block as long as you had 02-05 2.0L heads attached (machined to match first)...but that might cost a bit more.
    But for the sake of not having to screw with the wiring harness or ECU, or with having to tune...finding a complete 2.0L long block would be the easiest and cheapest.
