how much gain from ewg
Results 1 to 5 of 5
This is a discussion on how much gain from ewg within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; my current setup is 12 wrx sedan with intake, dp, axleback, grimmspeed ebc, pw tmic with a tp tune. I ...
    Registered User plasmarex12's Avatar
    Jan 2012
    so cal
    my current setup is 12 wrx sedan with intake, dp, axleback, grimmspeed ebc, pw tmic with a tp tune. I have been told that with an upipe(tuned) is bout 10whp. what can I expect with say a grimmspeed ceramic coated upipe with 38mm tial wastegate? (e-tuned for now). Im trying to weigh the cost vs power...
    boost is like alcohol, its fun and great in moderation, to much and something's gonna go boom.
    1) Don't bother with the ceramic coating option. Just pick up some heat wrap and wrap it instead. Just be sure not to wrap the flex section.
    2) The peak gains aren't necessarily going to be anything impressive, but there will be other areas of the curve where the delta values are higher
    3) Your injectors are pretty much maxed out as-is, so you'll want to consider upgrading them
    4) If you're not seeing boost creep, the install is enough of a PITA that I wouldn't bother without addressing #3
    Resident Tuner @ WTF Tuning
    Registered User keff108's Avatar
    Sep 2009
    PA
    I got that exact EWG setup installed on my 13 rex and honestly dont feel much power gain at all if anything. I went with the option because of boost creep.
    2013 Wrx Black Hatch
    Registered User chutoyy's Avatar
    Sep 2012
    Seattle-ish, WA
    Same here... Prevents boost creep, but in turn allows maybe a couple extra hp to be squeezed out of the engine.
    I got my header and up-pipe coated inside/outside for $170 at Embee in Tustin, CA
    2013 WRX Plasma Blue Pearl
    Sep 2012
    Seattle-ish, WA
    yay for double posts!
