Reliable but powerful 2012 WRX mods - Page 6
Page 6 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 76 to 90 of 237
This is a discussion on Reliable but powerful 2012 WRX mods within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I haven't personally driven a car with BCs, but they're generally not regarded as being a very good coilover. I'm ...
  1. #76
            MainFrame's Avatar
    Austin, TX
    I haven't personally driven a car with BCs, but they're generally not regarded as being a very good coilover. I'm fairly certain I could put together a similarly priced set of springs and struts that will out perform BC coilovers in both ride comfort as well as handling.
  3. #77
    Quote Originally Posted by MainFrame
    You may be "fairly" certain, but I'm 100% certain.
    I'll just leave this here...
    Cheap coilovers and droop - NASIOC
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  4. #78
    Jan 2012
    Philly Area
    Isn't one of the knocks against budget coilovers their longevity? I'd rather spend the same amount for a good strut/spring setup, which will improve my ride on the street and last as long as a more expensive coilover, then get cheap coilovers and have to replace/refurbish them frequently, even if that might end up costing the same as the expensive coilovers in the end.
    I guess my point is, if the goal is not to track the car do you need adjustable coilovers?
    If not, then why not get the good strut/spring combo that costs the same as the cheaper coilovers and will still give a nice ride for a DD and last longer?
    - Will
  5. #79
    Quote Originally Posted by Calvinball
    Inexpensive coilovers typically utilize inexpensive parts. Inexpensive parts have lower QC and less R&D. What that means is you get an inferior part that delivers inferior performance.
  6. #80
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    Agreed that some of the lower priced spring and strut options are a great option. I just stumbled on a deal for BC's that was too good to pass up and, from what I saw in my limited research, those spring/strut combos didn't lower the car enough for my taste. I've been enjoying the BC's handling, adjustability, and adjustable ride height ever since. Much better than the stock marshmallows.
    Also, my original comments toward avoiding springs on stock struts was based on the fact that springs, labor, then replacing the struts once they blow...would seem to me to justify another few weeks of saving up for an aftermarket set of suspension. Then you could reinstall the OE suspension and sell the aftermarket stuff when the car sells too! Another reason I said lower priced coilovers was, especially since I wanted to experiment with different ride heights myself and had a lower budget too, was because the OP obviously didn't want to spend a ton of dough given they were just looking to mount lowering springs on OE struts.
    Moral of all our conversation here, LOTS of options.....just what a consumer wants. And I have no problem admitting I'm no pro here, only been doing this stuff for a little over a year.
    Later
  7. #81
    Quote Originally Posted by MercRising
    Every time you adjust your ride height, you need to get an alignment. Factor in $100/adjustment (not sure what alignments cost in your area, but that's mine), if you don't DIY align.
    I'm not going to get into the aspect of "springs didn't lower enough", nor the fact that you could've bought a second-hand set of struts/springs for the same price (in fact, I had a setup that I'd put toe-to-toe with BCs anyday FS myself around that price). Read the link I posted earlier, as it specifically talks about BC coilovers.
  8. #82
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by MercRising View Post
    That's why you don't put lowering springs on OE struts in the first place. Assemble the aftermarket struts with the new springs, then install them..
  9. #83
    Mar 2012
    Littleton
    I would like to try struts and springs at some point just to see. What combos do you guys around here prefer?
  10. #84
    Jun 2013
    Im probably not going to get coilovers because this car is more of a daily driver( i have a 1972 240z im putting a 280z engine in that im getting fully rebuilt, bored .40 over, putting a cam in it, high performance carb, headers and exhaust) so im thinking ill probably just get swaybars for now and some new rubber. but i did find out i live within 5 miles of an e85 station so that is quite tempting... but i have decided im not going to dump close to 1 grand into an exhaust just for sound, but instead i am thinking about getting some el headers, along with the catless dp and tune etc. but i am worried about reliability issues with getting new headers for an engine like this. Does anybody have any feedback on first hand experience with el headers and reliability?
  11. #85
    Jun 2013
    also im wondering what kind of hp #s i would get w/ my new combo vs my old one:
    OLD:
    invidia Catless downpipe
    invidia cbe
    and of course a solid tune(precision tuning)
    NEW:
    catless downpipe
    stock exhaust
    el headers
    same tune
    and maybe an intake if that would give me some gains because of the headers
    I dont think i would want the e85 tune because i take roadtrips and i dont wanna have to worry about running out of gas or finding stations etc(like stated before, daily driver)
  12. #86
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    You cannot do this:
    Quote Originally Posted by kdeitrich View Post
    el headers
    and retain this:
    same tune
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  13. #87
    Registered User tesla317's Avatar
    Aug 2012
    ok im looking for something thats good, how much is a pretty good tire ? but not top of the line
    A little late for this post, but look at Michelin Pilot Super Sports.
    They are top of the line, pretty much beat all the other summer tires in all categories, and cost less. I got then for right at $800. They also have one of the best tread life of the summer tires.
    I did a lot of research for weeks before I found these. Considering they cost less than a lot of the other tires, and out perform them. Best bang for your buck!
  14. #88
    Quote Originally Posted by zax
    You cannot do this:
    and retain this:
    Well, you can, but it's not advisable, at least without logging to verify there aren't issues. Also, without altering the tune, you will not make use of the benefits of the ELH.
  15. #89
    zax
    zax is offline
    Nov 2008
    Let me clarify: I wouldn't retain the same tune.
    Facebook me here
  16. #90
    Jun 2013
    could you elaborate on why you wouldnt get the el header or retain the same tune?
