Reliable but powerful 2012 WRX mods - Page 14
Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 196 to 210 of 237
This is a discussion on Reliable but powerful 2012 WRX mods within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; nevermind. i may just go for the injectors, pickup, and fuel pump at once...
  1. #196
    Jun 2013
  3. #197
    Jun 2013
    comes to a total of $5221.XX haha
  4. #198
    Jun 2013
    Invidia Downpipe Catted Divorced Wastegate Subaru Models (inc. 2008-2013 WRX / STI)
    RSD Part #: INV HS08SW1DPC
    In Stock - Ships Fast!
    Ships to you within one business day from our Salt Lake City Warehouse.
    $509.60 $509.60
    AEM Fuel Pump 320lph
    RSD Part #: AEM 50-1000
    $104.15 $104.15
    Kartboy Short Shifter and Bushing Combo Subaru Models (inc. 2008-2013 WRX / 2005-2009 Legacy GT)
    RSD Part #: KAR KB-002-LEG-WRX08
    $165.00 $165.00
    Process West Top Mount Intercooler Subaru WRX 2008-2013
    RSD Part #: PRW PWTMIC07
    $982.14 $982.14
    COBB Tuning Short Ram SF Intake System Subaru WRX / STI 2008-2013
    RSD Part #: COB 715100
    $195.00 $195.00
    Perrin Equal Length Header Subaru Turbo Models (inc. 2002-2013 WRX / STI)
    RSD Part #: PER1 PSP-EXT-050
    $809.99 $809.99
    Perrin Cat Back Exhaust Sedan Subaru WRX / STI 2011-2013
    RSD Part #: PER2 PSP-EXT-347BR
    $1,169.99 $1,169.99
    Perrin Shift Knob Black Slim 5MT Subaru Models
    RSD Part #: PER1 PSP-INR-101BK
    $53.99 $53.99
    GrimmSpeed Boost Solenoid Subaru WRX 2008-2013 / Legacy GT 2005-2009
    RSD Part #: GRM 057032
    $105.59 $105.59
    Defi Red Racer Boost Gauge Imperial 60mm 30 PSI
    RSD Part #: DEF1 DF11502
    $214.20 $214.20
    Go Fast Bits TMS Respons Hybrid Blow Off Valve Subaru WRX 2008-2013 / Legacy GT 2005-2009
    RSD Part #: GFB T9001
    $262.71 $262.71
    Injector Dynamics Fuel Injectors Top Feed 1000cc Subaru Models (inc. 2002-2013 WRX / 2007-2013 STI)
    RSD Part #: IND 1000.18.02.48.11.4
    $480.00 $480.00
    Killer B Motorsport Ultimate Oil Pickup Subaru Turbo Models (inc. 2002-2013 WRX / STI)
    RSD Part #: KIL 070-110
  6. #199
    A couple things...
    The Turbosmart recirculation valve would save you a bit of money vs GFB, and I'd trust that one more.
    You'll need the accompanying airbox to go with the Cobb SRI (which adds an additional $115), or go with the AEM (additional $60).
    I'd urge you to go with the Invidia downpipe with two bungs (additional $15) and consider picking up an AEM UEGO, since it'll be easiest now to install a WBO2 in the car. Skip out on the shifter mods just yet, and pick them up down the line.
    Have you heard the Perrin exhaust in-person? I like the Q300 on sedans, which is $150 cheaper than the Perrin you have selected.
    Resident Tuner @ WTF Tuning
  7. #200
    Registered User TravTagz's Avatar
    Apr 2012
    NJ
    Where in SJ are you from? Check out Procom Racing in Toms River they're helping me with my build. My setup is Turbo XS catless DP, Grimmspeed Up-Pipe, Tial MV-R EWG, Grimmspeed MBC, NGK 1 step colder plugs, DW 850cc Injectors, DW65c Fuel Pump, Procom OEM+ block (forged pistons), Blouch Dom 1.5xtr (10cm), Procom FMIC + Intake, Tial Q BOV.
  8. #201
    Jun 2013
    Quote Originally Posted by TravTagz View Post
    no i havent heard of them. how much is a tune
  9. #202
    Apr 2012
    NJ
    I believe 450 for 3 maps on an AP... the first Friday of the month they usually have a Dyno Day/BBQ ($40dyno pulls no tuning)...good chance to check out the shop
  10. #203
    Jun 2013
    true. i may look into it. ive heard many good things about precision tuning tho
  11. #204
    Jun 2013
    im gonna wait to do the injectors and pump
  12. #205
    Quote Originally Posted by kdeitrich
    I think that's a mistake, considering everything you're already doing. Push things off for a bit, but when you go to get a custom tune, I think injectors/pump would be well worth your while.
    They will really allow you to make the most out of your modifications once they're installed. Install your downpipe/TBE and intake and flash the appropriate S2 map to tide you over, but I strongly urge you to reconsider not installing an upgraded fuel system. There's a good bit of power to be made with the parts you have listed if you have proper fueling, which you don't on the stock system.
  13. #206
    Apr 2012
    NJ
    At stage 2 you will be maxing out your injectors and pump I would make them a priority over a catback and even intake. The stock catback is fine for your power level goal so is the intake, a high flow filter is enough for the 320hp range.
  14. #207
    Especially with the fuel system to support it, an intake should be on the car when he gets a custom tune.
  15. #208
    Jun 2012
    A couple things...
    the OP is basically planning the same thing I am so might as well add to this thread, can you guys specify on the turbosmart BPV? which model?
    I plan to retain the stock exhaust so I'm thinking the Cobb DP is the best choice in that case.. I just don't want to attract cops on my daily driver
    so after reading the thread it seems the reliable and powerful mods to get are (if you retain stock exhaust):
    Cobb DP
    Intake
    Aftermarket BPV
    Aftermarket TMIC
    Pro Tune
    for the moment i'm content to only push it to 17 psi just because its been stated that going to higher might call for upgraded TMIC and BPV
    on that note what is the capacity of the stock injectors? I see recommendations to upgrade so what are their limits?
  16. #209
    Quote Originally Posted by crows
    There is one recirculating valve on RSD for Turbosmart.
    Cobb DP
    Intake
    Aftermarket BPV
    Aftermarket TMIC
    Pro Tune
    Decent setup
    StageII, pretty much.
  17. #210
    Jun 2013
    Turbosmart Recirculating Blow Off Valve Kompact Plumb Back Black Subaru / Mazda Models (inc. 2008-2013 WRX) thats the one im getting. im not gonna get injectors, fuel pump, or exhaust yet i dont think. ill post all the mods again (updated)
