Aftermarket TMIC question?
Results 1 to 14 of 14
This is a discussion on Aftermarket TMIC question? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Using my accessport what should i monitor or look for when i change out my factory TMIC?...
    Registered User BEASTmode632's Avatar
    Nov 2012
    Chatlotte, NC
    2015 Subaru WRX : ISC Coilovers........
    Same things you'd log before
    Resident Tuner @ WTF Tuning
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Blinker fluid temperature for one.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Palmyra, NJ
    Not to mention the exhaust bearing pressure (in PSI...mPA is usually skewed).
    Nov 2012
    Chatlotte, NC
    Yall really have nothing better todo
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by BEASTmode632 View Post
    Facebook me here
    Palmyra, NJ
    Well, yeah. We are on an internet forum posting stupid ****...of course we don't have anything better to do.
    I mean what I said. There's nothing additional you need to datalog because you put the TMIC on.
    Your boost tables may be messed up, you'll be hitting higher loads as a result, and your fueling may be off (without a WBO2, you can't verify this).
    May 2010
    Pittsburgh, PA
    Agreed. If you are changing your intercooler and (assumingly) not making changes to your tune, why log? Logging has various purposes, and we need to know a little more detail to help you in that regard. Are you looking to see if you are having detonation issues? Fueling issues? Boost issues?
    In my opinion, if you aren't tuning your own car, and you are concerned... Ask your tuner. Give Perrin a ring (in your case) and ask them if they forsee any issues.
    2011 STi Build Log
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I don't typically post on Internet forums...but when I do it means I have nothing better to do
    Nov 2012
    Chatlotte, NC
    Im just asking to see if there was anything inparticular i should be watching for that could cause problems. I am not tuning for it but should i? Can i change it and run it with out a tune or should i contact perrin about getting something changed in my tune.
    Jan 2012
    Philly Area
    - Will
    May 2010
    Pittsburgh, PA
    With an intercooler change, in your situation, I don't see any large issue. You should still be okay as far as injector headroom (or lack there of). I doubt you'll be hitting any detonation issues. I don't know if their boost correction tables will still be appropriate. That being said, you won't be taking much advantage of the new intercooler. I would probably bump up the boost a bit and check for any timing changes if it was me.
    After you put it on, look for any detonation for a while (FBKC, FLKC, IAM or DAM) and learned fuel trims (AFL #1). I wouldn't expect any more than you have now, personally. Afterwards, do a pull monitoring your boost related parameters and wastegate duty cycle with corrections. You may want to throw injector duty cycle on there as well. If you need more information, look through the links in my signature. I believe Part 1 will have any details you need as far as logging goes.
    2011 STi Build Log
    Nov 2012
    Chatlotte, NC
    Thats the kind of answer i was looking for. Thanks heide
