Camshaft/ engine blown NEED ADVICE
Results 1 to 15 of 23
This is a discussion on Camshaft/ engine blown NEED ADVICE within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Yesterday i was driving and my check engine light came on and and i heard a scraping sound when i ...
    May 2013
    Yesterday i was driving and my check engine light came on and and i heard a scraping sound when i put down the accelerator and i lost a significant amount of power, my cobb accessport was showing camshaft sensor errors and a bunch of camshaft related errors. And my A/F was all over the place. we lost power completely after a minute or two and pulled over. My engine and air intake was smoking and i had no oil which was fine when i checked last week.
    Im guessing i will need need new cam shafts if not a whole new short block or even a new engine. So i was wondering
    1. If anyone knows what is going on (the shop is checking it out tomorrow)
    2. If i need new cams should i get after market ones even if i am running stock turbo? I might upgrade in the future once i get the money.
    3. If i need a new engine what would you guys recommend doing?
    1. Nobody knows yet.
    2. No.
    3. That depends on which car you own. The older the car, the more likely I'd be to find a used engine, swap them, and that's that.
            MainFrame's Avatar
    Austin, TX
    2. No.
    ^this
    May 2013
    its an '08 WRX with 119k miles, Perrin DP, K&N Air intake and cobb stage 1 tune, so not much yet which is why cams wouldnt help but i dont want to pay for stock ones now then upgrade in a year or two
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by willyb524 View Post
    Sounds like your blown engine was a result of not being tuned for your mods. Cobb's stage one OTS map is for 100% stock cars only.. you have to use a stage two map if you have an aftermarket downpipe.. and Cobb does not make a map for your intake (although the AEM intake map might work).
    Cams need to be matched to your turbo.. unless you're running something 30r or larger, I would not bother with aftermarket cams.
    May 2013
    Someone also said that it could be the intake cam gear since it is made out of plastic, but there is no way to know until they look at it. but i figured stage one would be better since i dont have the full turbo back yet, i will be getting a cat back in the next few weeks though, also when this happened i was also on the interstate running the economy mode map.
            MainFrame's Avatar
    Austin, TX
    That will do it every time. You cannot run a stage one map with an aftermarket downpipe and expect the engine not to blow.. and on top of that the economy mode map is junk. It was just a matter of time.
    Cam gears don't just fail, but running the wrong map for your car will definitely ruin the engine.
    May 2013
    well my engine is gone, the timing belt skipped a tooth and everything train wrecked from there. the shop said 7k for a motor and install. for a 35k mile WRX motor from a scrap yard. anyone have any suggestions? im a college student so i dont have 7k, im in the army so i have a tad more money then other students but i still cant drop 7k on repairs, i need my car and i have no idea what to do.
    DIY a used engine, stock, and leave it all stock.
    Palmyra, NJ
    Or scrap the car for a part out and use profit from that to get a beater.
    Take out a loan for $7k...use $7k worth of credit cards? I dunno...its either find the money to do a swap, discuss payment options or where to source another engine for cheaper, or find another car.
    May 2013
    well i want to stick with the car, ive put a lot of time into it and i dont want to see it get parted out, anyone know of good places to look for used engines?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    It is a tough situation man. Look around on NASOIC and whatnot to see if anyone is selling an engine. There is no cheap way around this. When/if you get it fixed, make sure and do a ton of research (or ask a ton of questions on sites like this) before you slap parts onto it. Sucks this is your only vehicle. Good luck.
    Palmyra, NJ
    Nasioc classifieds...ebay...Google...
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    1. you need a map from perrin for the perrin intake
    2. you need a STAGE 2 map for an aftermarket downpipe.
    3. you need a STAGE 2 + perrin intake map for your car
    4. if you need a new engine and you dont want to scrap the car. then get a new engine.......
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
    Jan 2012
    Philly Area
    Also, was the timing belt service completed?
    - Will
