Camshaft/ engine blown NEED ADVICE - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Camshaft/ engine blown NEED ADVICE within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Calvinball Also, was the timing belt service completed? Yea.. those bearings in the pulleys will always get ...
    Registered User Valkator's Avatar
    May 2013
    Wisconsin
    Yea.. those bearings in the pulleys will always get you if they were not changed with the belt.
    Not to mention the tensioner is good to replace too
    Car: 2013 DGM WRX 5 Door
    May 2013
    supposedly the timing belts were replaced before i got it. so im going to call the dealer and try to blame it on them for not replacing them right, but i was also considering buying the engine parts individually and putting them together myself which might be more cost effective
    Palmyra, NJ
    Quote Originally Posted by willyb524 View Post
    So you're experienced with pulling a motor out, splitting the heads off, replacing valves, springs, and retainers? As well as inspecting/replacing cams? And pulling the block apart to make sure that no damage was done to pistons/cylinders/rings/etc?
  6. #19
    May 2013
    Wisconsin
    And trying to slide those wrist pins thru those holes in the block... ehhh. Get better at it over time though.
  7. #20
            MainFrame's Avatar
    Austin, TX
    The shop is trying to gouge you.. you can get a "new" used motor for $1000-$1500, and the install labor shouldn't cost more than $800.. more like $500. All together you should be out the door for less than $3500.
  8. #21
    May 2013
    yeah im not experienced with it at all, i would get help from some friends with a good amount of experience though, the shop called a scrap yard and apparently they said 5.2k plus they would want to replace the water pump and stuff. i was looking at websites like topspeed that modify engines and sell them, it looks like that would even be cheaper then the scrap yard. i figure this is a good opportunity to get a bit more power out of the engine while im at it.
  9. #22
            MainFrame's Avatar
    Austin, TX
    A built engine is not going to make any more power than a stock one.. if anything it will make less.
  10. #23
    Palmyra, NJ
    Yeah that scrap yard is highballing the **** out of you. That's a retarded price.
