External Wastegate Help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on External Wastegate Help within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; seriously guys? I bought a full turbo back exhaust system that's on my car, and my tuner said he could ...
    Mar 2013
    seriously guys? I bought a full turbo back exhaust system that's on my car, and my tuner said he could weld a custom pipe onto my piping for my ewg I bought all I asked for was help with where I can just get a pipe to bolt for the low that will bolt on to my exhaust to install it, im not tryna pay a couple hundred for a weld job I would rather buy a pipe. I am a newb to turbos, and subarus.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by gokartmar27 View Post
    seriously guys? I bought a full turbo back exhaust system that's on my car, and my tuner said he could weld a custom pipe onto my piping for my ewg I bought all I asked for was help with where I can just get a pipe to bolt for the low that will bolt on to my exhaust to install it.
    An EWG has little to do with the downpipe or turbo-back exhaust! Unless you are planning to dump the wastegate back into the downpipe, the Uppipe is the piece of the exhaust with which you will be most concerned. Pay special attention to Header designs as well, as many ELH are not compatible with V-band EWG setups.
    I am a newb to turbos, and subarus. sry for being used to American muscle.
    That's OK, there is plenty of information on this board
    Comment removed
    It is in your best interest to keep these comments to yourself, as this sort of negativity reflects poorly upon yourself and specifically violates our forum policies. Consider this a warning.
    Edit: on second thought, I'm removing the quoted comment as it lends nothing to this thread (OP, you know to what comment I'm referring).
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Mar 2013
    thank you
  6. #19
            MainFrame's Avatar
    Austin, TX
    As Zach stated, EWG has little to do with your turbo back exhaust. I would recommend buying an EWG uppipe rather than trying to make your own.
    We will need to know what headers you are using, what EWG you have, and what downpipe you have (some downpipes, TurboXS for example, make EWG fitment difficult).
  7. #20
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    The grimmspeed ewg uppipe fits fine with my Turboxs downpipe.
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  8. #21
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by lytlec View Post
    Also depends on the EWG you're using. I have seen several reports of the GrimmSpeed pipe location NOT fitting with the TurboXS downpipe, as well as the TurboXS EWG pipe not fitting either. I'm pretty sure the lower profile of the v-band attachment of the newer Tial MV-S and MV-R EWGs aids in tight spots. The only two uppipes I have seen with guaranteed fitments with TurboXS downpipe are GTSpec (which I don't know if you can even get anymore), and P&L.
    My P&L 44mm EWG uppipe fit fine with my TurboXS downpipe. ::cough::and it is also for sale!::cough::
  9. #22
    May 2010
    Pittsburgh, PA
    Just as a note, the grimspeed kit I got I had to modifiy to fit with the new Tial v-band. Apparently the kit was designed around the turboSmart v-band flange, which at the dump side, is slightly smaller. To resolve this and use it with my Tial, I had to carefully sand down the flange on the dump tube.
    OP, you really should do some reading on the subject to understand a bit more when leaping to an EWG. It's not really a 'plug and play' mod in my opinion. Your tuner can get going for you and everything... But I feel it's useful to understand a bit of what is going on under the hood at that point. Understanding the basics of your boost system can help you diagnose or at least identify any issues while driving, before they blow your engine up.
    2011 STi Build Log
