COBB AP V1
Results 1 to 8 of 8
This is a discussion on COBB AP V1 within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I was wondering if anyone is running V1 with this setup, DP and catback only. Those are the only mods ...
    Registered User RSMWRX's Avatar
    Jan 2013
    Orange County
    COBB AP V1
    I was wondering if anyone is running V1 with this setup, DP and catback only. Those are the only mods I'm looking to do and am curious to see if the V1 can handle. I don't want to drop 500-600$ on a V2 so any information would be very valuable!
    Palmyra, NJ
    As long as it has a Stage 2 map on it, and is compatible with your car, then yeah a V1 will work fine...
    Be warned though that Cobb hasn't supported the V1 for quite some time now.
    Why not look for a used V2? Plenty of them out there.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    I think you're misunderstanding what the AP does. All it does is upload a datafile to the ECU. Of course the V1 can "handle" that. The real question would be finding a used V1 compatible with your car. Cobb still has archives of the V1 Stage II maps on their site.
    The problem is that the V1 is no longer supported by Cobb, so if you ever want a protune at some point, you'll need to get a V2.
    If you really want to save money, go OpenSource. Plenty of support, and basic maps are free.
    2007 Outback 3.0R wagon
    Jan 2013
    Orange County
    Quote Originally Posted by Rambo View Post
    OpenSource? I'm unfamiliar with that, could you explain?
    Jan 2013
    Orange County
    Does OpenSource work with the stock ecu as long as I have the Tactrix cable?
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    It does. IT's an adapter that allows to connect a laptop running the OpenSource software: Romraider and learning view. Romraider is also what talks to ECU and installs the new map. first pull a copy of the installed map, then install new. That new map could come from a email based tuner, like Torqued Performance, there are a number of them. Mine is tuned with Torqued Performance, others have used many other e-tuners. You'd usually pull some logs, with Romraider, the tuner goes over that end makes adjustments, sends another iteration of map, until the logs show "good". You can also use this to monitor current readings, like AP, read out DTC and reset CEL... Do a search on "romraider", "tactrix"...
    The cable is like $160, Software is free, i.e. OpenSoure... Laptop is probably a given, it was in my case.
    May 2007
    orlando flawduh
    OP, you have a 2007. a v1 WILL NOT WORK for your year.
    you can only use a v2.
    desiree
    Resident Tuner @ WTF Tuning
