Perrin thermal DP blanket - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
This is a discussion on Perrin thermal DP blanket within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ohhh I thought you mean the car's warranty for some reason. Derp. Makes sense....
    Palmyra, NJ
    Feb 2013
    Columbia SC
    So eventually my catted downpipe will become a "resonated DP"? Lol
    2013 WRX sedan - MODS = pretty much every bolt on besides a bigger turbo.
    Registered User clt-wrx's Avatar
    Mar 2012
    MERICA
    Changes the heat that is retained in the metal. And the wrap causes it to corrode faster. And to be clear I'm talking about the warranty on the dp itself.
    has anyone here experienced this? im just wondering over what period of time you would see corrosion with wrap being the main variable.
  6. #19
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by clt-wrx View Post
    Its the reason why the the metal turns black (you will notice this in any picture of piping that was shiny stainless steel and is now brownish black after heat wrap is removed).
  7. #20
    Registered User DwnShft4WRX's Avatar
    May 2012
    NorCal
    So is it not recommended to heat wrap a stainless steel down pipe? Or are you guys talking about the oem down pipe?
  8. #21
    Apr 2013
    I've got a Perrin DP blanket on order. I ordered it last Tuesday or Wednesday, hopefully it will be here soon.
    I'm still on my stock DP so longevity is not a terrible concern. From speaking with someone over at Perrin a while ago I was told damage to the DP from the blanket isn't a real concern. For some reason the person I spoke w/ said the UP is the weak spot as far as stock pipes are concerned.
  9. #22
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    I'd just buy a roll of titanium heat wrap, instead.
    I have a question what purpose does heat wrapping your exhaust do? Wouldn't that just create higher temps for the exhaust? I was under the impression that heat wrapping would help cool the exhaust that's what I thought the purpose was however how in the hell would it cool it? The more I think into this matter wouldn't it raise your exhaust temps and egt? Other then the purpose of controlling temp through heat wrap what other purpose would this serve?
  10. #23
    May 2012
    Colorado
    Another question here.. my invidia dp was shinny where it connects to the waste gate now it is discolored like yellow, purple and a slight brown this would be due to high temps near the wastegate right causing the downpipe to discolor a bit? and no my dp is not heat wrapped.
  11. #24
    Nov 2012
    Using wrap reduces the radiant heat (lowers temps under the hood), and maintains hotter exhaust gases. Hotter gases exit the system faster.
    There will always be discoloring over time. Heat wrap will just increase the discoloring (and is said to make the metal more brittle over time). Probably not quick enough to cause issues for a long time though. You probably would want to use some kind of seal spray or whatever if you wrap. Lots of people on here have wrap on various piping (up pipe, headers, downpipe).
  12. #25
    Quote Originally Posted by frenziedcage
    Heat wrap is an insulation wrap. There are reflective tapes you can put on that would help keep heat out (ever see a TMIC with the metal endtanks shiny gold?).
    The greatest benefit of wrapping pre-turbo exhaust is to maintain EGTs. Hotter air is faster air, and will aid in spool and response; a byproduct is that it reduces underhood temperatures. The greatest benefit of wrapping post-turbo exhaust is reduced heat in the engine bay; a byproduct is that it keeps the air hotter so it will move faster out the exhaust (it's not as important here as pre-turbo). Therefore, if someone is looking to wrap their downpipe, I would only bother wrapping until it bends towards the rear of the car by the firewall.
    That depends on the wrap material. Fiberglass wrap you want to coat; the newer titanium wraps, you don't.
    Resident Tuner @ WTF Tuning
  13. #26
    May 2012
    NorCal
    Should the cat be wrapped as well?
  14. #27
    Nov 2012
    Quote Originally Posted by DwnShft4WRX View Post
    No...that would be a waste...probably only the bend section of the downpipe that isin the engine bay (like mentioned above). Some people wrap the whole downpipe but the cat would be overkill.
  15. #28
    Apr 2013
    Blanket came in today and its a pain in the ass to get on with the down pipe installed. The lower heat shield bracket has to come off which doesn't come off peacefully. You have to bend the bracket a little bit on the down pipe in order to get bracket to slip past and out of the car.
    Once the heat shield bracket is out the rest of the installation is pretty straight forward. My hands are small enough to fit between the tranny and the DP so I didn't have too much trouble with the wire wraps, so....
    The end product looks great!
  16. #29
    May 2012
    NorCal
    Alright so no wrapping the cat. But how would I deal with the issue where the cat is melting the nearby rubber boot?
  17. #30
    What downpipe do you have?
