Tmic question?
Results 1 to 9 of 9
This is a discussion on Tmic question? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey fellow clubwrx peeps... I will be buying a tmic(process west)from my buddy hear in the next few days. My ...
    Registered User WrxPower's Avatar
    Mar 2012
    Florida
    Tmic question?
    Hey fellow clubwrx peeps... I will be buying a tmic(process west)from my buddy hear in the next few days. My question is will I or can I put this on my car without tuning for it right way. My buddy is running a stage 3 map from TP and I will do the same but I don't have the other required mods yet (ebcs,aftermarket bpv). I know without a tune I'm not going to get the full potention of the tm. Like a dp you have to tune for it. Is the tm like this?
    2012 wrx
    Stage 2 Torqued Performance
    Cobb intake
    Invidia catted dp
    AP
            MainFrame's Avatar
    Austin, TX
    Should be alright.. I would log to make sure, but if anything it should make your current tune safer.
    Mar 2012
    Florida
    Oh noooo. I hope when you say it will make my current tune safer your not referring that the TP map is unsafe. I have made a big step in the past month into the mod world so all I know is what I have researched and seen first hand. If you could share with me what you think about the map i am on it would be greatly appreciated.
  5. #4
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Although I believe some people are not the biggest fans of TP maps, I think he is referring to the fact that a quality TMIC will flow more air and reduce the amount of presure that is lost (lower presure drop). Also better cooling, which you would get with a quality TMIC, will reduce the chances of a pre-ignition, which could cause damage. (Although I could be misinterpreting his statement!)
  6. #5
            MainFrame's Avatar
    Austin, TX
    Although I believe some people are not the biggest fans of TP maps, I think he is referring to the fact that a quality TMIC will flow more air and reduce the amount of presure that is lost (lower presure drop). (Although I could be misinterpreting his statement!)
    Well.. the decreased pressure drop is the only thing I would worry about. If you're boosting more then you might venture into load zones that have not been tuned, which would be a problem. I was more referring to the increased cooling capacity of the better TMIC to help prevent knock.
  7. #6
    Nov 2012
    Haha I just added a similar statement through an edit as you wrote that!
  8. #7
    Mar 2012
    Florida
    Would one step colder plugs help me with pre ignition. Not sure when these are or should be installed on the car. Btw thanks for all the info!!
  9. #8
            MainFrame's Avatar
    Austin, TX
    I would only use stock heat range plugs. If you're having pre-ignition problems your tune needs to be fixed.
  10. #9
    Quote Originally Posted by WrxPower
    Without seeing the map, no one can do that.
    No
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
