Air oil separator
Results 1 to 15 of 15
This is a discussion on Air oil separator within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi all! I have done some searching on here and although I found a little bit of info (mostly bickering ...
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Air oil separator
    Hi all!
    I have done some searching on here and although I found a little bit of info (mostly bickering), I still wanted to pose the question. What are the general thoughts on air oil separators? I was eyeing the grimmspeed one, and before I drop the money I figured I would see if anyone else is running these and if you think it is a worthwhile investment. I am currently only stage 1, but this friday night I am getting my turbo back exhaust installed, at which time I will be flashing to stage 2. So for all intensive purposes, you can consider me stage 2
    Thanks ahead of time for any insight!
            MainFrame's Avatar
    Austin, TX
    The Crawford AOS is widely regarded as being better design than the GrimmSpeed one.. that said, I wouldn't run one on my car. I prefer to keep the blow-by junk out of my engine, rather than circulating it back into the oil pan.
    Dec 2011
    Pottstown PA
    ^that. Ebay catch can FTW!
    Marky Mark
    My bugeye build
    MinoskePhotography
            MainFrame's Avatar
    Austin, TX
    I actually run a Peterson catch can that I have modified to pull vacuum from my intake. The problem with most catch cans is that they are VTA and to properly evacuate gases from the crank case and heads you should be pulling vacuum from them.
    Nov 2012
    Ok, so if a catch can is the way to go then I will take that route. One of my friends actually recommended the same thing. Is there any good brand out there that would be a decent quality that I could add on without any major modifications (which as the one that you did to your peterson)? I know that some people would say a catch can is a catch can is a catch can, but I have heard the same thing about downpipes, and I still chose to buy a nicer quality one!
    Thanks!
            MainFrame's Avatar
    Austin, TX
    The Peterson catch can is a good one.. all you really have to do is remove the breather on the top and attach a line to your intake, but it should be a rather large line, preferably clear so you can see if you're over flowing.
    The only issue with doing it this way is that you need to check and empty the can on a regular basis, and you'll need to top your oil off more regularly.
            MainFrame's Avatar
    Austin, TX
    super slow server double posting fail
    Jan 2012
    Philly Area
    Hi all!
    I have done some searching on here and although I found a little bit of info (mostly bickering), I still wanted to pose the question. What are the general thoughts on air oil separators? I was eyeing the grimmspeed one, and before I drop the money I figured I would see if anyone else is running these and if you think it is a worthwhile investment. I am currently only stage 1, but this friday night I am getting my turbo back exhaust installed, at which time I will be flashing to stage 2. So for all intents and purposes, you can consider me stage 2
    Fixored!
    Sorry, I had to
    When you grow up with an editor for a father...
    - Will
    Palmyra, NJ
    Quote Originally Posted by Ruh Roh View Post
    Ha I forgot Kunal just gave me one. Wonder if I should put it on.
    Nov 2012
    Fixored!
    Sorry, I had to
    Haha no problem...I can't even see what you changed!
    Nov 2012
    Ok cool I will look into this. Thanks for the info, much appreciated!
    Dec 2011
    Pottstown PA
    why didnt he use it??
    Marky Mark
    My bugeye build
    MinoskePhotography
    Jan 2012
    Philly Area
    Maybe I'm more like a grammar ninja then!
    - Will
    Palmyra, NJ
    No idea actually. He didn't even install it.
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    like my moroso dual catch can setup.
    went to that from the grimmspeed aos.
