2006 wrx build
Results 1 to 6 of 6
This is a discussion on 2006 wrx build within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Building my 2006 wrx. Wanted to get some opinions before I start. Current setup: Sti tmic Cobb sf intake Stromung ...
    Apr 2013
    Murrieta ca
    2006 wrx build
    Current setup:
    Sti tmic
    Cobb sf intake
    Stromung dual tip turboback.
    Exedy stage2 clutch, lightweight flywheel
    Cobb ap, dynotuned 265whp/326wtq @16.9psi
    Starting with motor work, and breaking it in on my current setup.
    Motor:
    JE 100mm pistons
    Brian Crower rods
    Brian Crower 272 stage2 cams
    Brian Crower springs/retainers kit
    Resurface heads
    ACL race bearings
    ARP headstuds
    Gates timing belt
    Turbo: eyeballing the Tomioka td-06 20g twin scroll kit
    Or Garrett gt3071r
    Supporting mods:
    Walbro 255 fuel pump
    Injector dinamics 1000cc injectors (e85 in the future)
    Turbosmart recirculating blow off valve
    Turbo XS fmic
    Grimspeed boost solenoid
    Tune
    Have I forgotten anything?
    Goal:
    I'd like to be somewhere around 350-400whp/wtq.
    I am aware of the 5spd not being the strongest, but I don't plan on hammering it. Atleast not until I swap a 6spd
    Open to some opinions and tips from people who have done similar builds
    Moderator Donkey's Avatar
    Da boonies,Va
    I would get the heads ported /polished and TGV deletes with the Grimmspeed 8mm phenolic spacers. Upgrade the fuel lines.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Apr 2013
    Murrieta ca
    *Forgot to add port/polish.
    And also, I'm hearing mixed thing about tgv deletes. Do you have any experience with them?
    Thanks,
    Da boonies,Va
    Quote Originally Posted by Newbie123 View Post
    Thanks,
    What mixed things are you hearing? In my eyes they are only a performance restriction. I'm not sure I have ever heard anyone regret doing TGV deletes. I ran them on my 02 WRX.
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    This. TGV deletes is an excellent mod... and if you do your own port and polish with block off plates, the best $70 you can spend.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    You're on a stage 2 clutch personally not something I'd do but if it floats your boat go for it especially since you're running s2 on a stock 5spd. In theory you want your clutch to be the weakest part not anything else.
    As for the fuel pump 255lph would work but I personally would eyeball something a bit bigger Especially if you are gonna run e85 on gt3071r
    For the boost solenoid I'd recommend doing a hybrid setup much more efficient.
