Stage 3? Or go another way? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on Stage 3? Or go another way? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Calvinball What about contacting a shop and setting it up to bring the parts there and put ...
    Palmyra, NJ
    What about contacting a shop and setting it up to bring the parts there and put them on/tune it all at once?
    Ps my vote is for some suspension/brake work as well, just a personal opinion but I enjoy improvement in those areas just as much as moar powah!
    Says the most stock guy ever...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by elblanco1987 View Post
    Thinking of going stage 3 (TMIC, fuel pump, one step colder plugs, stage 3 TP tune)
    Who's gotten this from stage 2? How big of a difference is it? Worth the money?
    I would absolutely consider an injector upgrade at this point, though a more efficient TMIC will allow for more injector electrical headroom (car can be run leaner at WOT).
    If you've not worked on the brakes and suspension at this juncture, now would be the time to do it! If you accelerate harder, you'll need to brake harder and corner harder as well!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Dyno is hard to come by, there isn't one anywhere around here so idhave to drive for hours without a tune. I'd get the download tune for now and get it dynoed later
    Any shop worth a damn would send you a map so you can get there. Especially with your setup, it'd be simple.
    Resident Tuner @ WTF Tuning
  6. #19
    Jan 2012
    Philly Area
    - Will
  7. #20
    zax
    zax is offline
    Nov 2008
    However, in my experience, most shops charge for a base map.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
  8. #21
    Quote Originally Posted by zax
    If you have a tuning appointment, you need to get there. You give them a limp map, nothing more. They may charge for the base map, but that may just be to cover themselves, and would likely give you a discount (for that amount) on the tune itself. Otherwise, GFY, I'll take my car elsewhere...
  9. #22
            MainFrame's Avatar
    Austin, TX
    Charge for a base map, then said charge is applied to the final tune. If they're charging for the map to get there, then again for the tune that's just bad practice.. I don't know any shop that would do that (but I'm sure some would).
    I agree with the need for better turning and stopping power. I also feel that why piss the money away on stage 3 for minimal gains when you can just add a new turbo and injectors on top of those stage 3 mods and have a considerable jump in power.
  10. #23
    Jul 2012
    Webster, MA
    I went from stage 2 Cobb, to stage 2 TP, to stage 3 TP on my 2013 WRX. I noticed a jump between the TP stage 2 tune and stage 2 cobb tune, and tp stage 2 to 3 of about equal proportions. I would definitely do it again, but now that I've done it, i wonder if there are other ways of getting that same power (ELH, EWG). Of course, now that I have stage 3, I think I'll probably be adding some of the other stuff anyway.
    If you are going to use TP, then you need an AFR, and a way to get him video of it during logs. So far, my injector cycles are still within reason on a daily driver, but any more HP past stage 3 = new injectors for sure for me.
    But, to be serious for a moment, I think you want to consider where your 'end game' is. If you plan on doing a turbo eventually, then there are things that you'd need to do anyway for that upgrade. You might as well do that now for safety and 'overdesign' of the build. For instance, now that I'm at stage 3 and comfortable there, I wish I had done injectors and other miscellaneous stuff for more overhead on the tune since I just started looking for a new turbo, ELHs and an EWG (read the post right above mine for reasons why!). And I would also plan on getting a dyno tune once you reach your 'end game'. It is worth it for both piece of mind and for some level of bragging.
    In my opinion, I would recommend that you at least look at getting better brakes as part of your build. Rally sport direct has a $500 upgrade package that gives you a bit of a brake increase without going to a full-blown big brake package.
  11. #24
    zax
    zax is offline
    Nov 2008
    Both Agile and IAG charge for a base map AND a tune.
    Facebook me here
  12. #25
    Both Agile and IAG can lick my taint...at the same time
