Results 1 to 15 of 20
This is a discussion on Cold Air or Short Ram???? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; i have an 02 wrx wagon and im stuck between an Injen CAI and a K&N Typhoon Short Ram, i ...
    Mar 2013
    Flagstaff, AZ
    i have an 02 wrx wagon and im stuck between an Injen CAI and a K&N Typhoon Short Ram, i know the cons and pros between a short ram and CAI, just asking for some opinions!
    Oct 2011
    Santa Ana, CA
    Neither. Stockbox ftw!
    Posted from a fone.
    Texas, United States
    Quote Originally Posted by UEDan View Post
    Posted from a fone.
    ^this.. unless you are running a larger turbo and front mount IC. Stock ram air box doesn't fit with traditional FMIC piping.
    Mar 2013
    Flagstaff, AZ
    not yet but i will be soon. going with the weapon r- secret weapon
    Quote Originally Posted by snowonmysubie View Post
    What's that? eBay brand?
    Mar 2013
    Flagstaff, AZ
    no, because i will eventually be upgrading the turbo and setting up a FMIC, and personally the CAI sounds better, performs better, and it gets rid of that acordian rubber hose, yes i could just change the hosing but id rather go the full mile
    What's the difference in sound between a SRI/CAI?
    Most intakes don't eliminate the Post-MAF hose.
    What turbo are you going with that you bring up a FMIC?
    Registered User Motoxdude6's Avatar
    Jan 2013
    Lubbock, TX
    CAI- cold air intake
    SRI- HOT air intake
    which do you think would be better? lol
    Registered User Andor's Avatar
    Mar 2013
    Boca Raton, Fl
    I Personally went with CAI. I do wish sometimes i went with a SRI as in south florida, it does rain, ALOT! and driving through puddles or mini ponds scares the shyt out of me! It def. does sound really nice though!
    2007 UGM STI: Vigilant Street series short block, ClutchMaster FX350 clutch w/ lightweight Flywheel, Invidia catless DP, Invidia N1 Race CBE, Grimspeed EBCS, Walbro 255 FP, BC Coils, AEM CAI, 8k lights, Driver Mod
    Registered User InsaneManiac's Avatar
    Jun 2012
    San Diego
    The problem with a CAI is that you need to get your car tuned for it. Question for you though, how much power are you looking to do with a FMIC and a bigger turbo?
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by InsaneManiac View Post
    Let me clarify: The problem with many CAI is the introduction of a 90 degree bend immediately before the MAF, which changes the MAFv scaling. Truthfully, a SRI can suffer from the same problem with a poorly designed MAF housing. As a general rule of thumb, if you change the intake or MAF housing, you really should adjust the MAFv table...
    Facebook me here
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    If you think about it both intakes eventually run the air through a hot turbo then an intercooler. Any cooling gained from a CAI is lost once it goes through the turbo. On an NA car maybe a CAI might work better but on a turboed car seems kinda dumb. I would go SRI eliminate unneeded bends and lower the risk of getting water in there.
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
    Quote Originally Posted by wrx1234
    The problem is, the IAT sensor (which the ECU uses for compensations) is in the MAF sensor. It doesn't matter what turbo or I/C you have.
    Without relocating the IAT sensor, a SRI is far less desirable as opposed to the OE airbox or a proper CAI.
    Sep 2009
    Dover DE
    When i say SRI i'm thinking of the cone filter being where the original air box is. That would keep the MAF in the same spot (at least on my 09) with the same diameter pipe.
    2011 Sportwagon TDi
    Quote Originally Posted by wrx1234 View Post
    But the cone filter draws air from right there, where as the stock box draws it's air from the ram air scoop in the front of the car next to the headlight..
    The main problem with the IAT sensor in a short ram is if you're drag racing or something. While your car is sitting, idling, in the staging lanes the IAT will read very high, causing the ECU to pull timing. Then when you go for your pass the air is cooled as soon as the car starts moving, but it takes some time for the ECU to add timing back in, so your car will be down on power.
