Ordered a turbo blanket today
Results 1 to 15 of 19
This is a discussion on Ordered a turbo blanket today within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I got it from PTP, just wondering how many of you all have them and if it was hard to ...
    Jan 2009
    Md
    I got it from PTP, just wondering how many of you all have them and if it was hard to install while on the car? Did you notice your engine temps were lower on a regular basis?
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Very easy to install.
    FYR, the purpose of the turbo blanket isn't really to decrease engine temperatures. The primary purpose of the blanket is to keep the energy IN the turbocharger. The less heat lost through the header/uppipe/turbine, the more energy is harnessed to drive the compressor. Engine temp reduction is really an ancillary effect: particularly the temperature on the lower side of the TMIC.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    zax
    zax is offline
    Nov 2008
    Facebook me here
    Palmyra, NJ
    I know there was a group by of them a few months back (I didn't pull the trigger on it)...so a few people around here have em and like em.
    Apr 2004
    Southeastern PA
    Mods & Pics
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    I gots one! I would say its easier then changing the drivers side headlight bulbs...
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Jan 2009
    Md
    Yeah, I had read about it helping with spool time etc. I know it obviously does help to keep temps down. I took off my heat shield when I changed my DP since it didn't fit because of the bellmouth, I know there is a DIY on how to use the OE heatshield with aftermarket DPs though. If I don't use the heatshield, would the TB do just as good of a job though?
    Quote Originally Posted by Methodical4u
    Better
    Resident Tuner @ WTF Tuning
    Jan 2009
    Md
    Better
    Ok, all I needed to know, thanks man.
    Jan 2009
    Md
    ok, I did the install... pretty easy to do, especially getting under the car where you can reach everything better. How tight is thing supposed to be on? If it can move back and forth a bit, does it need to be tighter? I don't want the arm to move it out of place.
    Jan 2009
    Md
    Nevermind... I got back under the car and redid the whole thing lol. It was bothering me to much. It's not loose, but it can move a little. I just don't want the arm to wear a hole in it. I wonder if I could use some wire to go around the turbo from top to bottom to fold those edges down a little?
    Aug 2012
    Alexandria, VA
    Welcome to the Turbo Blanket club
    I installed mine last weekend when I put a new Cobb Downpipe on my '13 WRX. Did the overkill of a downpipe blanket and new heatshield from Perrin with my TB. Heat in the engine bay shouldn't be an issue this summer; I hope! Install the Torque Performance Stage 2 with AEM intake on my Cobb AccessPort also. The power increase over Stage 1 is really noticeable.
    Ordered a Nameless Axleback exhaust just to give the car some sound with the new power. Really thought about just getting the catback system from Cobb, but the sound clips of the Nameless exhaust just sounds so sweet and $500 cheaper then a full catback system. Will post back at the end of the month how it all works out.
    Jan 2009
    Md
    Quote Originally Posted by Delnari View Post
    Did you get the Perrin blanket or the PTP? I bought the PTP. I actually thought it would go all the way around the turbo, but the bottom is exposed. I guess that doesn't mean it's a bad thing.
    Registered User chutoyy's Avatar
    Sep 2012
    Seattle-ish, WA
    PTP + Grimmspeed Heatshield for me!
    2013 WRX Plasma Blue Pearl
    Aug 2012
    Alexandria, VA
    I read on here that Perrin sourced their blanket out to PTP, so the PTP should be as good but only cheaper than the Perrin. PTP offered colors and since I have a red theme going on under the hood I went with the red blanket
    If PTP had a thermal blanket for the downpipe I would have used that as well. I did follow the Perrin suggested instructions for wrapping the wire on their blanket for my PTP. Seems very secure with no movement.
    Sidenote, looking at the photo above, Jason from Nameless Performance suggested to me that you should not wrap your downpipe with exhaust wrap if you drive where there is heavy rain or salt on roadways. He said the water/salt gets into the material and stays trapped causing permature corrision of the pipe. Even though most vendors use top brand Stainless Steel they are not indestructable! Better to leave an air gap between the pipe and exhuast shielding (aluminum or blanket) to allow excess water/salt to evaporate. Granted the thermal wrap adds great heat protection. The other methods allows for longer life of your exhaust.
