TD04L Turbo- Details
Results 1 to 9 of 9
This is a discussion on TD04L Turbo- Details within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hi, I'm pretty new, and I hope I have published in the right place.. (If not, I would be happy ...
    Mar 2013
    hi,
    (If not, I would be happy if managers can refer to the right place)
    I bought a used TD04L,
    I am looking for technical data on the Internet but without eny success..
    And how can i know if its a 13T or 19T or 17G ?
ID:	112875Click image for larger version.
    Moderator Donkey's Avatar
    Da boonies,Va
    Take more pictures. If this is an OEM Subaru turbo then it is probably a 13T. Alot of people/companies do modify the stock turbo by replacing the 13T compressor wheel with a 19T and machine the compressor housing to fit the new wheel. Only way to 100% know is to remove the compressor housing and measure the inducer and exducer.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2013
    Thanks a lot mate,
    I'm a little concerned about the state of the compressor wheel,
    If it's Critical and requires renovation, Or the axle is in good - quite reasonable condition ?
    I'll wait to hear your opinions..
    Mar 2013
    Aug 2012
    Tucson, AZ
    those fins look shot. or about to be
    Mar 2013
    Some videos will illustrate:
    Da boonies,Va
    It's the standard Subaru td04L-13T
    2002 FORESTER S
    1998 FORESTER S
    Mar 2013
    updated pics at courant condition, (your diagnosis, opinions...)
    Is the axle comes as a single unit with the turbine?
    The nut / bolt is very tight and can not be released without unwanted power force.
    Da boonies,Va
    Looks like the compressor wheel is junk. Half of the pictures are out of focus but it looks like the turbine wheel might have made some contact with the turbine housing. You can buy a fully assemble CHRA and just reuse the turbine and compressor housings.
    2002 FORESTER S
    1998 FORESTER S
