Does this require tune?
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
This is a discussion on Does this require tune? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So currently my 2011 STi is on the COBB stage 2 + SF intake tune with an invidia catted DP, ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    So currently my 2011 STi is on the COBB stage 2 + SF intake tune with an invidia catted DP, COBB SF intake + airbox, and nameless performance axleback, other then that its stock, My question is, do I need a tune for new headers? Going to be going for a tune soon but if I need a tune for them I'll do them before I go for a tune, if not I'll tune now and then install after the tune when i have the money for them.
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yes.
    Pay careful attention when selecting the size of the primaries. Primary size should be matched to your setup. Slapping on large-diameter headers will harm your performance more than help. However, a well-matched set of ELH when properly tuned will greatly increase your Volumetric Efficiency in the mid range.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User SoFloRex's Avatar
    Jul 2012
    West Palm Beach
    Sorry I can't answer your question man (I'm going to assume yes) but one question I have for you is, is your invidia DP hooked up to your stock miid pipe? I was looking to get that same DP but didn't know if I would have to go complete TBE. Also, when you put in the DP did you get a tune immediately after that, or can I put it on and wait til I save $$ for a tune?
    Thanks in advance and, again, sorry I can't help you.
    Nov 2011
    North Jersey
    Quote Originally Posted by SoFloRex View Post
    First, I went with a GrimmSpeed adapter, RallySport sells them, as well as many vendors on this forum, was only 35$ when I bought it. As far as the tune goes, I retuned the car (using the cobb AP) before i even turned the engine over with the new DP. I was told as long as you dont create any boost you shouldn't be fine to drive the car a few miles, but personally, I'd wait, when you personally hold the new DP, and compare it to the old one, you can see what a big difference in design.
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    You pretty much can expect to tune for everything but a catback exhaust. You really need to tune for anything that will somehow change the flow of exhaust or air through the turbo.
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
    Jul 2012
    West Palm Beach
    Quote Originally Posted by Mike193 View Post
    So you didn't get a pro tune with anything you have on your car? Just used the AP?
    Sep 2009
    Dover DE
    It's best to get a stage 1 tune first... this step will open up your ability to tune your car whether it's open source or an access port. After that you got what you need for your stage 2 tune, that way you can bolt the DP on and tune it all at the same time. If you can't afford to do both at once then the logical step is to go for a stage 1 tune then stage 2 (downpipe+tune). If you plan on doing a stage 2 tune and getting a pro tune... bolting the downpipe up and taking a short drive to a tuner will not hurt just stay out of boost. But your scenario is different since you can't afford the tune, that is why you need to go stage 1 first like 99% of the people in your situation. Also IMO the stock to stage one jump is bigger than the stage 1 to stage 2 jump.
    2011 Sportwagon TDi
    Jul 2012
    West Palm Beach
    Quote Originally Posted by wrx1234 View Post
    Perfect. Thank you. Sorry OP for highjacking your thread. lol
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    i barely felt anything going stock to stage 1 on my 2013. but stage 2 felt like a world of difference. maybe it was just my car didnt take well to the stage 1 idk. the AP was only registering 14.2 psi(didnt have proper boost gauge at the time) which is within the 15.0psi +/- 0.8 that the map notes showed. it could also be the ACN 91 map just sucks since our gas is so lame out here lol
    Sep 2009
    Dover DE
    I haven't looked at the map notes for the cobb tunes since 2009, but i am pretty sure the stock to stage 1 jump is bigger than the stage 1 to stage 2 (cobb tunes). My current tune peaks at 18.5 (stage 2)
    2011 Sportwagon TDi
    zax
    zax is online now
    Nov 2008
    The gains have little if anything to do with the increase in boost pressure.
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Headers can shift VE significantly, so yes, you do need to tune for them.
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    SoFlo...I have that adapter and no use for it. PM me if you need it.
    Oct 2005
    Late Devonian
    Are you referring to the headers? They were in a side discussion about stage 1 & 2 - increased boost pressure is a major factor there.
    zax
    zax is online now
    Nov 2008
    Nope, I'm referring to the change from Stock to Stage 1
    I'm sure that the timing/fueling enhancements have a much greater impact on the increase in output over the increase in boost pressure.
    Facebook me here
