Does this require tune? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
This is a discussion on Does this require tune? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Mike193 As far as boost goes, I've been pushing 18 since stage 1 and 19 since stage ...
  1. #31
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    Quote Originally Posted by Mike193 View Post
    As far as boost goes, I've been pushing 18 since stage 1 and 19 since stage 2. Not sure if 19 is boost creep but the car is on the low wastegate duty and going for protune soon
    What stage 1 tune did you use that pushed you to 18PSI? What did you use to measure?
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
  3. #32
    May 2010
    Pittsburgh, PA
    A pro tune will not "fix" boost creep. It is a mechanical problem.
    Is the OP running a catless down pipe? In which case, he probably is getting boost creep. If not, I've never heard of anybody having actual boost creep issues with a catted down pipe on the stock turbo.
    If it's just a boost spike and his boost at redline is okay, I doubt that it's actually boost creep. I'd put money on the OTS tune just being a bit too high on the duty cycles or low on the corrections.
    2011 STi Build Log
  4. #33
    The OP isn't "spiking" or "creeping" at all...target boost is 18 for S1 and 19.5 for S2.
    Quote Originally Posted by wrx1234
    Based on his first post, I'd guess the Cobb one
    Resident Tuner @ WTF Tuning
  6. #34
    Sep 2009
    Dover DE
    Cobb kicking 18PSI at stage one? that doesn't sound good.
    2011 Sportwagon TDi
  7. #35
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by wrx1234 View Post
    Argue that with Cobb:
    https://static.cobbtuning.com/cobbtu...-13+Intake.pdf
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  8. #36
    1) STI (not a crappy OE TMIC like the 08+ WRX)
    2) Intake
    3) Conservative timing/fueling
  9. #37
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Meh, I'm confused. If 19.5 is target boost then I'm gunna not worry about it and live on. If somethings wrong and a tune will not create a solution then I need to figure out how to have the car run correctly. I'm planning on selling my Rubicon soon and getting a muscle car as a weekend warrior and keep the STi as a daily, I need it running good.
  10. #38
    Oct 2005
    Late Devonian
    Your map notes are your friends - page 4
    What is "boost select" BTW (not being sarcastic - IDK).
  11. #39
    May 2010
    Pittsburgh, PA
    I'm a bit confused... what is wrong again? Did I miss something?
    I thought you were posting that you were looking to pick up some headers, and wanted to know if you would require a tune.... Not that something was wrong with your car.
    2011 STi Build Log
  12. #40
    Nov 2011
    North Jersey
    The boost is spiking at 19.1-19.5 when it first hits boosts then settles at 18. I personally don't know much and was under the assumption this could be solved through a tune and am now pretty sure i'm being told its a mechanical problem and a tune will not help my situation. I'm confused, very confused.
  13. #41
    Jan 2012
    Philly Area
    Don't quote me, but that sounds normal.
    - Will
  14. #42
    Do a line graph of Boost vs RPM and post it up.
  15. #43
    Oct 2005
    Late Devonian
    No no no.
    You said you were spiking or creeping, and other people got confused. You're hitting your boost target, and it is dropping from there - that sounds normal. If it is a very abrupt up/down you could work on it with a tune but it probably isn't an issue (if it is an issue you would see knock in that load/rpm area). It should continue to taper at the top RPM - if it is going up instead that would be a mechanical issue probably or possibly tunable. I highly doubt it if you have a catted DP. Post the graph that EJ suggested so we can see.
  16. #44
    Nov 2011
    North Jersey
    I will post a graph in a few days, only computer I currently have is my highschool laptop which is beyond blocked. literally 95% of websites are blocked on this thing, luckily this site works, the chat doesn't however. Finally I'll go out and get one of those 300-400 dollar small notebooks ill just dedicate to the subi lol
  17. #45
    zax
    zax is offline
    Nov 2008
    Whaaaa??? I don't even?
    Lost track.
    Facebook me here
