Changing DAM?
Results 1 to 15 of 16
This is a discussion on Changing DAM? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; When I was going to summit point yesterday, I noticed my DAM go from 1 to .9 then eventually .8. ...
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Changing DAM?
    When I was going to summit point yesterday, I noticed my DAM go from 1 to .9 then eventually .8. At first I thought I had a hiccup in my tune. Then on the way back home, the closer I got to home the DAM slowly increased to .9 then back to 1. Why could that be? I live in Baltimore and summit point was in WV I believe. Could it be the air?
    A car is only as good as its driver
    Resident Tuner @ WTF Tuning
    Jul 2012
    Baltimore
    So. If u understood correctly, that was the ecu's way of switching or adjusting to the new environment?
    Quote Originally Posted by SubiEj255
    The car felt the need to pull timing globally at some point, and then slowly determined it was safe to go back to full advance.
    Jul 2012
    Baltimore
    So under those conditions, was it safe to do a wot pull?
    Oct 2005
    Late Devonian
    It was "safe" but you should avoid it if possible.
    How many tanks of gas were involved - one tank on which it went down and a new tank on which it went up?
    It could have been the elevation change, but the stock tune shouldn't have any trouble accommodating that.
    Edit - it doesn't look any different in elevation even, so no, it was not the air.
    Jul 2012
    Baltimore
    Well I didn't do a wot pull because I was unsure. The changes were all within the same tank of gas. I was thinking it was the elevation change. Also, I'm not running the stock tune.
    Oct 2011
    Santa Ana, CA
    Which tune are you running?
    Posted from a fone.
    Jul 2012
    Baltimore
    I'm running a custom tune from a tuner at GoodSpeed
    Oct 2011
    Santa Ana, CA
    I'd log and take the data back to them and demand a retune. A custom tune, in my opinion, should be safe and definitely not drop the DAM/IAM.
    Posted from a fone.
    Oct 2005
    Late Devonian
    It will drop if you get questionable gas. See if it comes back over the next few tanks. I wouldn't want it de-tuned over one event.
    Oct 2011
    Santa Ana, CA
    Thing is he said it was over the same tank.... I guess I am jumping the gun a bit.
    Just monitor it for the next few tanks and see what happens.
    Posted from a fone.
    Oct 2005
    Late Devonian
    Yeah, IDK. The elevation isn't really any different. It could have just been heat soaked too. If the gas is marginal it could run up and down. Otherwise they should definitely fix it.
    Jul 2012
    Baltimore
    This is an old thread, but after this event I got another map. Seemed to work ok until Saturday (roughly 1000 miles using the map) & once again my car pulled timing & my DAM was at .1, but this was after a pull. I pulled a log & the guy from NASIOC (Clark) said my car has a cracked ringland from how my car pulls timing. Could this be true? Also what are the symptoms of a cracked ringland?
            MainFrame's Avatar
    Austin, TX
    Blue smoke and low compression would be a sign of a cracked ringland..
