Bpv with tmic - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Bpv with tmic within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Mines on the side...... Wrx...
    Feb 2013
    Columbia SC
    2013 WRX sedan - MODS = pretty much every bolt on besides a bigger turbo.
    Registered User Yamahar6311's Avatar
    Aug 2012
    Los Angeles
    Ahh that's right. Cool!!! Well glad to help 😁
            MainFrame's Avatar
    Austin, TX
    Blow off valve and bypass valve are just different terminology for the same thing. What's important is if they're recirculating, or VTA.. you want a recirculating valve.
  6. #19
    Feb 2013
    Columbia SC
    Thanks for the help guys
  7. #20
    Aug 2012
    Los Angeles
    Does he need a recirculating because it a Wrx?
  8. #21
    Feb 2013
    Columbia SC
    Wrx and STI both have recirculating. U can't have "vent to atmosphere" unless you tune for it
  9. #22
    Aug 2012
    Los Angeles
    Do not let this make you think you absolutely need one, however. Most turbo cars, such as the WRX/STI have a stock bypass valve that is designed for the levels of boost the car is running normally that will work perfectly. The only reason you would want to upgrade to an aftermarket BOV is if you want to run quite a bit more boost than stock (20psi on the WRX/STI). At this point, the compressor surge can be greater than the stock BPV can handle.
    Problems: There is one certain problem that aftermarket BOVs can create. The air that they release has already been measured by the mass air sensor, so when this air is gone after the BOV blows off, the ECU will be injecting the wrong amount of fuel, causing the engine to run rich for a second. This can damage the catalytic converter after time. This can not be fixed with engine management.
    Take all these factors into consideration before buying a BOV. Happy modding!
    Article Source: http://EzineArticles.com/1110055
  10. #23
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Yamahar6311 View Post
    He needs a recirculating valve because Subaru uses draw through MAF based tuning logic. (also, recirculating valves are much less prone to leaking due to the vacuum drawn on the recirc side of the valve.. couldn't help but notice you have a HKS SSQV installed, one of the main atmospheric BOVs notorious for leaking)
    Not that your car absolutely has to run a recirculating valve, but they do perform better.
  11. #24
    Aug 2012
    Los Angeles
    😓 I know, I bought it when I got it a year ago. I will unfortunately wait till it does then by a reliable bpv.
  12. #25
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    From what I heard, on the up side it will better your throttle response
    Righttttt.....
    I'm going to assume you are NOT running 30+ PSI, a blow-through MAF, or Speed Density fueling. In which case, what you posted is incorrect. The stock BPV is more-than capable of relieving excess pressure and it is unlikely you will experience any improvement in transient response unless you satisfy the above conditions.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  13. #26
    zax
    zax is offline
    Nov 2008
    The main consideration for upgrading the stock BPV is leaking NOT compressor surge! A stock 2002-2007 USDM WRX/STi will hold up to 20 PSI. After this point, the BPV may not seal under boost resulting in a boost leak. 2002-2007 metal BPVs could be modified to hold higher levels of boost, unlike the newer plastic BPVs. JDM STi BPV will hold up to approx. 25 PSI of boost. At boost pressures 20 PSI and under, the stock BPV is far superior to an aftermarket piece.
    Facebook me here
  14. #27
    Aug 2012
    Los Angeles
    Righttttt.....
    Once again I only heard and your right, never got into specifics but good know. I learn something new everyday. Thanks zax
    powered by a monkey chasing a banana
  15. #28
    Feb 2013
    Columbia SC
    But my stock bpv was plastic though not metal like you said the ones you mentioned
  16. #29
    Aug 2012
    Los Angeles
    I'll let zax answer this. He seems to know it all.
  17. #30
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by elblanco1987 View Post
    2008+ WRX use the Legacy GT style layout, which includes a plastic BPV. It is not [easily] possible to modify this BPV for high boost, and they are rumored to leak at pressures above 17-18 PSI. Most 3rd gen owners looking to modify past OTS stage 2 tunes opt to use a Forge BPV.
    Facebook me here
