I need help with downpipes for my 2013 Wrx - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on I need help with downpipes for my 2013 Wrx within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by anthony360 More so than an intercooler ? If you mean does an IC by itself, being put ...
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    Quote Originally Posted by anthony360 View Post
    If you mean does an IC by itself, being put on an otherwise stock car, net more gains than a DP and tune on that same stock car....then heck yes the DP is a better bang. The DP and move to Stg2 is the essential liberation that any WRX owner needs to feel. Its a large change from stock, not only in terms of power but also in general drivability because the aftermarket tunes are so much smoother.
    From my reading it seams that the IC will eak out a few more ponies from your current turbo/intake/exhaust etc...but is simply not the bump in the pants that opening up your turbo outlet from a small hole to a high flow larger dimension DP.
    Stock DP only lows the turbo to utilize a small part of its exit. Notice how much of the stock DP is blocked off. Only the pipe diameter itself is available to shove air through.
    Aftermarket Divorced...now the turbo can get more air out faster which means we can get more air into the engine faster from the intake side....which means we can get more power. I course that's very basic conceptually, a little more complicated in reality.
    Registered User anthony360's Avatar
    Mar 2013
    Hialeah
    thanks for the info!
    im new to car mods and need all the info i can get. once i got mine i was planning to buy the intake intercooler and downpipe all at once. with a tune obviously.
    Mar 2012
    Littleton
    Bahhlin...I was able to do the intake, EBCS and 3" TBE all at once....whole new rig after that. Love my car now....more like lust my car now!
    GL with it all! Do it right once, not crappy thrice!
