Good next mod? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
This is a discussion on Good next mod? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Nah man, this is info I'm looking for. Great advice....
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    A car is only as good as its driver
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    Pretty nice used market between here nasioc and the old 3gwwrx dot kahm.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    E85 isn't quite a cheap mod.
    You'll need injectors (~$500), a fuel pump (~$100), and a tune (~$400-500). In the end, that comes out to be around a grand.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #19
    Jul 2012
    Baltimore
    That's true. I understand that. With a tweak in my tune, how much power could I get with a TMIC?
  7. #20
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by SubiEj255 View Post
    What TMIC?
    Sent from my Nexus 7 using Tapatalk HD
    Facebook me here
  8. #21
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Check out this guys thread...He installed a ProcessWest TMIC.
    PW intercooler installed and Protuned
  9. #22
    zax
    zax is offline
    Nov 2008
    I think a quality TMIC would be an excellent idea, and here's why:
    1.) Lower pressure drop. A quality bar-and-plate TMIC has a much lower pressure drop across the core than the stock TMIC. The stock WRX TMIC has approx. a 3 PSI pressure drop at 20 PSI. This means that while the turbo outlet pressure is 20 PSI, the pressure of the air entering the cylinders is 17 PSI. As such, the turbo has to be run further out of the efficiency range to achieve equivalent boost with the stock TMIC. A good bar-in-plate intercooler will have less than 1 PSI of pressure drop at 20 PSI. The turbo will spool faster and hold boost longer into the rev range compared to the stock TMIC.
    2.) Injectors as a limiting factor. Tuning a Stage 2 WRX will result in reaching the peak capability of the stock injectors with the required electrical headroom. With an aftermarket TMIC, you will achieve increased charge cooling, and thus be able to lean out your mixture at full boost. Thus, you will be able to sneak by with more power for a given injector size with proper timing adjustments.
    Facebook me here
  10. #23
    Mar 2012
    Littleton
    Great info for sure. TMIC appears to be a great base addition for bigger power mods in the future too. I am torn on buying one because for the same money, or close, you can go FMIC and it looks amazing and cools amazing too. And there's options out there for keeping your front safety beam now so that's non-isue. TMIC's just seem like a lot of cash to spend if you don't plan to go much past stage2 right?
    And ZaX, for Corn, can't you just spend $600 in injectors/pump and then $120 on a Tactrix and $150 on a open source tune ....if you're OK with tuning that way, via email and all. Eric Minehart runs E-85 himself so, the Torqued Performance Open Source E-85 from him would probably be pretty good. Plus, the safe gain on corn because of it's resistance to knock allows for a great value at under $1000 and about 15-20% more giddyup.
    Hopefully I'm not too far off base here with the material, i read forums a lot and they are often WAY biased as we all know. It's just that I'm in stage 2 myself and have been trying to decide on what of these mods to do next on my own car.
    TOO MANY OPTIONS, WHAT A PROBLEM TO HAVE!!
  11. #24
    Palmyra, NJ
    Quote Originally Posted by MercRising View Post
    To that I say...if you don't want to go past Stage 2 Off-The-Shelf tune...yes. But if you are planning on going the protune route...it will help you get a good amount of power, and increase reliability across the board that would otherwise be left on the table if you didn't have one comparatively.
    As for Corn...you can spend that for the Open Source tune...but that would be equiv for an etune or an off the shelf tune again. I'm not aware of any tuners that do that for E85, unless Eric from TP does do E85 tunes via email...It's a fickle thing to tune for and generally needs to be done in person with road-tuning or a dyno tune to really ensure it's running correctly...ergo why you'd need to do a protune to properly run it. I'd honestly not want to get that done via email, no matter how reliable the tuner may be (not knocking Eric at all!)
  12. #25
    Mar 2012
    Littleton
    Great points on the protune vs. e-tune. I've read that the Corn tune is a bit more fickle so the electronic emailing back and forth with log/send/reflash/repeat would be a bit annoying for sure.
    And I hope to never imply that I know much more than a field mouse in the tuning arena. I'm just here gathering/sharing info as much as I can.
    Sorry if this wasn't the OP's intended route of the thread but...some great info bouncing around here!
    Cheers all!
  13. #26
    I would NOT tune a car on anything but pump gas without both a boost and wideband gauge. Even at S2, I'd prefer to see them on the car.
    Resident Tuner @ WTF Tuning
  14. #27
    zax
    zax is offline
    Nov 2008
    I'd pump your gas
    Facebook me here
  15. #28
    Mar 2012
    Littleton
    Cheers all!
    Looks like you avatar is tuning up that Pink Panther with no gauges!
    No but seriously, I'm no tuner!
  16. #29
    Jul 2012
    Baltimore
    PW
    What TMIC?
