WRX uppipe, downpipe, exhaust questions. - Page 2
Results 16 to 30 of 38
This is a discussion on WRX uppipe, downpipe, exhaust questions. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Will most likely stay stock motor and stock turbo for a good long while with just "stage 2" mods/tune. Im ...
    Mar 2013
    Will most likely stay stock motor and stock turbo for a good long while with just "stage 2" mods/tune. Im just curious if catless uppipe/downpipe/stock catback + stage 2 tune would be good, or if catless uppipe/downpipe/catback + stage 2 tune would be much better (more than a 5hp difference) than stock catback.
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    Depends on your other modifications .. if you're running a large turbo then a good catback and headers can open up a lot of power. On stock turbo the power gains from a catback would be negligible. You can gain some power from a decent equal length header
    . But for you're money you would be better off buying a larger turbo if you're just after more power.
    +1
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
    May 2012
    Colorado
    Quote Originally Posted by 05WagonRX View Post
    Staying stock motor and Turbo stage 2 gains are similar in what you will net. A good estimate is about 50+whp with a good tune. However each car will see different whp gains then the one beside it someone going stage 2 might only see 20 whp while the car next to it will see 50whp
  6. #19
            MainFrame's Avatar
    Austin, TX
    No.. a good ELH would probably make more than 5hp, but it will also cause your turbo to spool later (and you will need a custom tune).
  7. #20
    No.. a good ELH would probably make more than 5hp, but it may also cause your turbo to spool later (and you will need a custom tune).
    It depends on the header...
    Resident Tuner @ WTF Tuning
  8. #21
            MainFrame's Avatar
    Austin, TX
    Depends on the turbo too. I dunno if there is a header out there that will spool a stock turbo as quick as the stock manifold. Although my Perrin ELH was spooling the vf22 pretty dang quick.
  9. #22
    Mar 2013
    ok. stock 2.0 wrx engine and stock turbo. would it be ok to run catless uppipe, cobb down pipe, and stock catback with stage 2 tune? or would there be a problem going into the stock catback?
  10. #23
            MainFrame's Avatar
    Austin, TX
    That will be just fine.
  11. #24
    Mar 2013
    Ok, I was just making sure that the Cobb catted downpipe will bolt up to the stock catback without any problems. Thanks guys!
  12. #25
    May 2012
    Colorado
    Yep that should work.
  13. #26
    Mar 2013
    So the Cobb catted downpipe will bolt up perfectly to the stock catback, and maybe one day a Cobb catback?
    Or is there a better catted downpipe that bolts up to the stock catback? I just want a catless uppipe , then a downpipe with one highflow cat to stock catback plus stage 2 tune. Which catless uppipe do you recommend? Which catted downpipe do you recommend to bolt up to the stock catback?
  14. #27
    May 2012
    Colorado
    I like the grimm speed up pipe. It has a flex joint. Just beware that you'll need to get rid of the egt code it'll throw since it doesn't have a egt bung built into the uppipe many other up pipes are like this too. I think its a 2.2ohm 1/2watt resistor you'll need. Invida makes some good down pipes.
  15. #28
    May 2012
    Colorado
    Its all preference on what you wanna get really since its your car.
  16. #29
    Mar 2013
    Are there any aftermarket downpipes that are meant to bolt up to the stock catback, or are they all meant to bolt up to larger aftermarket catbacks?
  17. #30
    Jan 2012
    Philly Area
    Cobb, I'm pretty sure.
    - Will
