Results 1 to 15 of 26
This is a discussion on Need Battery advice, its time for a new one within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So my first battery lasted 3 years (cali heat kills them), and this one has lasted 3.5 years. While it ...
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    So my first battery lasted 3 years (cali heat kills them), and this one has lasted 3.5 years. While it still starts fine, the plastic case is swollen and is leaking acid out of the top and has corroded my factory battery tie down.
    So I'm thinking going sealed this time. AGM most likely.
    My car has no stereo upgrades, no aux equipment.
    How do Optima red tops hold up?
    Braille?
    any others?
    Thanks.
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    avoid optima batteries. they are nothing but expensive headaches
    Moderator Donkey's Avatar
    Da boonies
    The original Optima's were awesome. From what I hear quality control has gone down. If you don't need anything special Exide or Interstate are pretty good. Exide does make AGM batteries.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2006
    Nor Cal
    Good to know, I had an Optima red top about 10 years ago and it was pretty good...sad if their price went up and quality down.
    I had an exide orbital in my truck about 10 years ago and that thing was a pos. only good thing was the warranty. I think Kragen gave me 4 for free. But I guess that was a long time ago.
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    I've always gotten batteries from Les Schwab. Nothing fancy about them, but no problems either, and of course Les Schwab has a great warranty. You have those in Nor Cal, right?
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Jun 2006
    Nor Cal
    Yeah we have Les Schwabs.
    Dec 2011
    Pottstown PA
    Quote Originally Posted by 06wrx4me View Post
    im waiting for mine to go. starts fine but i try to clean off the corrosion from time to time lol
    Marky Mark
    My bugeye build
    MinoskePhotography
    Texas, United States
    I ended up having a lot of problems with the newer generation Optima Red Tops.. after switching to a Yellow Top I haven't had an issue. They don't come cheap though, and they're heavy as hell.
    I decided against buying a new battery for the Impreza even though the car needed one. Instead, I bought a new battery for my wife's SUV! I then took the "old" battery from the SUV, that was perfectly fine, and shoehorned it into the WRX by trimming the casing and the battery box.
    This killed two birds with one stone: I don't have to worry about my wife's battery going bad since she has a new one, and I don't have to worry about the WRX's battery since it's now got much higher CCA.
    I now have a Group 24FS in the Impreza rather than a Group 35.
    Behold:
    Battery size maximum?
    Jun 2006
    Nor Cal
    Do you need different battery cables for the Optimas?
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    Optima does well as long as it is kept maintained and always have a charge of 11.5 or higher. I have a yellow 660 and a red 900 (CCA) and they both do not handle cold well. I use an Exide stock sized battery in Winter and just keep the stereo under a roar.
    Optima is also heavy... fwiw, the performance gains do not outweigh the losses.
    Heat can be prevented to a slight degree by using a battery box, like a Summit Racing or Jegs model, which can be had for not too crazy $.
    Once discharged, an Optima does not take recharging well. Not sure why mechanically, I just know from the two I have here. One is a warranty replacement (the RedTop 1050/900) and the second one failed the same as the first. Froze.
    Braille is a lightweight battery made for starting and basic functions. I don't recommend them for stereo upgrades or lighting upgrades.
    It is easy to build a fast car, and it is easy to build a quiet car.
    It is hard to build a fast, quiet car.
    http://www.clubwrx.net/forums/builds...on-list-7.html
    Jun 2006
    Nor Cal
    Quote Originally Posted by Impreza2.0 View Post
    Do you need different battery cables? Does the positive cable reach?
    If you get the absolutely correct Optima, no; if you get the almost right Optima, yes. I don't know the part numbers off hand though, sorry; however if you search around you will see there are two different configs one can buy. Ostensibly both work however only one is a drop in. Shop with care.
    I suspect red # 8020-164 could be correct but ignore me, ring Optima directly and ask specifically if you need cables or if it'll drop right in.
    I replaced mine, and I use both top and side terminals. Side for factory ground and starting, top for additional grounding mods and aftermarket power (stereo, etc).
    From what I remember, you CAN reach the positive side terminal with the OEM starter cable, but it's stretched real tight and I kept having problems with it. Installing a longer cable was inexpensive and easy.
    Jun 2006
    Nor Cal
    What if you bought something like this for the side post to adapt to the factory cables, do you think it would reach?
    http://www.oreillyauto.com/site/c/de...0365&ppt=C0005
